Latest: lio94
Overall: 17181
Online Now [173]:
Visitors: 172
Today: 9532
Total: 141093016
Forums › The Car › 206 Talk › Mystery Cable disconnected
mdstone
PostPosted: Mon Apr 04, 2011 6:58 am Up
Hi, I noticed a black cable that appears to be disconnected but there doesn't appear to be anywhere to connect it. It is located in the bottom right corner behind the plastic cover you remove to change the headlight. There is a grey cable next to it that is already plugged in but this one is just dangling next to it. Any ideas what this might be for?
PostPosted: Mon Apr 04, 2011 7:47 am Up
It sounds like you have the dual headlight plugs. The disconnected one is for the earlier frosted H4 headlights.
MrrNoName
PostPosted: Mon Apr 04, 2011 7:58 am Up
yup as said above, its a H4 plug for an earlyer version of headlights, and you can see the H7 plug plugged in to the newer set
mdstone
PostPosted: Mon Apr 04, 2011 11:06 am Up
Nice one, thanks
Peugeot 206 GTi
PostPosted: Mon Apr 04, 2011 11:41 am Up
look like this?
Then yeah its a h4
