Online Now [320]:
Visitors: 318
Bots: 2
Today: 29585
Total: 105293005
Forums › The Car › 206 Problems › how do i know if water pump is working?
PostPosted: Sun Apr 03, 2011 9:16 am Up
reason being...
i had car running for about 10mins and temp got up to 90, now seems bit fast to me?? rad was stone cold, so was water tank too Confused fan was cutting in and out too.
engine has naff knocking noise from below i just thought bottom end was stuffed maybe its just naff water pump?
thanks ben.
PostPosted: Mon Apr 04, 2011 1:12 pm Up
bump Very Happy
D4NTP
PostPosted: Mon Apr 04, 2011 1:16 pm Up
Have you checked the thermostat opens?
PostPosted: Mon Apr 04, 2011 1:19 pm Up
suposse i could take it out and test it never thought of that Embarassed
one thing tho, when running even when cold does the water returning to header tank go into tank via the small top pipe i cant remember on these cars?? no water is moving at all in the header tank.
D4NTP
PostPosted: Mon Apr 04, 2011 1:25 pm Up
Check the stat first. If it's not opening you won't get any flow through the radiator/block/tank.
stevedude
PostPosted: Mon Apr 04, 2011 2:26 pm Up
aint water pump run off the timing belt?
sounds like ya need to flush the system out, change thermostat, is there any gunk in water?
Happydays
PostPosted: Mon Apr 04, 2011 2:27 pm Up
yep,
stevedude
PostPosted: Mon Apr 04, 2011 2:30 pm Up
well if water pump was not working then wouldnt the belt snap!
thats why ya always change pump when doing timing belt, least thats what i was told, before someone jumps up and down because i might be wrong lol
Happydays
PostPosted: Mon Apr 04, 2011 2:33 pm Up
i had one go on my old car while it was spinning the blade inside the block wasnt (so garage said), thats when i 1st got it from garage so they fixed it for me.
so thats why i was wondering,
stevedude
PostPosted: Mon Apr 04, 2011 2:36 pm Up
oh i didnt knew they could break that way, thought they either went around or jammed up, lol
have you bled the system. could have air trapped in it
Happydays
PostPosted: Mon Apr 04, 2011 2:38 pm Up
well thats what i was told when it went wrong with my old car (before i confident in messing around with this stuff) unless they were trying to fob me off Laughing lol
D4NTP
PostPosted: Mon Apr 04, 2011 2:49 pm Up
Usually the water pump impellor breaks up over time due to the antifreeze and the fact they tend to be plastic. The belt still drives the pump but it can't move any coolant, that then causes bits of the impellor to get into the cylinder head. If the impellor is u/s make sure you account for all the bits before fitting the new pump as it can quite easily block the head and overheat. If the pump seizes then yes it can snap the belt, unusual though.
Good practice and common sense says change the pump when you change the belt.
PostPosted: Sat Apr 09, 2011 9:22 am Up
tested stat today and no movement Very Happy
thanks Very Happy
