Latest: cogeim7
Overall: 17185
Online Now [458]:
Visitors: 457
Today: 222307
Total: 147496610
Forums › The Car › 206 Problems › rear axel problem
rear axel problem
axelrose13
PostPosted: Tue Apr 05, 2011 3:35 pm Up
hi lads, this seems to be the place i can get the help i need.
fitted a replacement axel on my 1400 hdi van from a 14 hdi car, everything about new axel seemed fine beforhand but when driving the van still seems to have rear wheel steer on lefthand corners as woth old axel which was defo knacked as could kick wheel and it was asif loose, but this axel wheel has no play .
what i have found is there seems to be a difference on height between wheel and arch on either side,
is it poss this axel is sound just not setup right??
hope so as axel was 240 plus a ton to fit
ty indvance
a rose
PostPosted: Tue Apr 05, 2011 3:38 pm Up
Where is the axle from? Was it a recon?
axelrose13
PostPosted: Tue Apr 05, 2011 3:40 pm Up
from ebay the guy said an 07 car with 26000 miles so thought no major probs
a rose
PostPosted: Tue Apr 05, 2011 3:47 pm Up
i would check if the torsion bar is set up properly
P.S. and you pay 240 for a drum axle? Confused Laughing
l_jacka
PostPosted: Tue Apr 05, 2011 3:48 pm Up
axelrose13 wrote:
from ebay the guy said an 07 car with 26000 miles so tought no major probs
Never trust any f****r!!
Could be that this axle is fubbered too... Crying or Very sad
You paid 260 for axle and fititng must be around 120
Should have got yours recon and the recon company offer free fitting too
Always ask for advice before splashing out big $$$$$ on job like this.
Looking to buy my first peugeot 206
axelrose13
PostPosted: Tue Apr 05, 2011 3:49 pm Up
would that make tha van get halfway round a corner then back end swing out? like rear wheel steer
a rose
there should be a sticker on the axle saying the manufacturing date of the axle
PostPosted: Tue Apr 05, 2011 3:51 pm Up
anything could happen if things are not setting up as they should
get the garage who fit the axle check it for you
axelrose13
PostPosted: Tue Apr 05, 2011 3:52 pm Up
lads im in the highlands, paid 140 for axel, 80 delivery, 100 fitting plus its abs which made it harder to find
a rose
PostPosted: Tue Apr 05, 2011 3:55 pm Up
like i said above, get the garage who did the job check it for you.
one side higher than the other is never going to be right.
either the torsion bar is not set yp correctly or one of the dampers is knacked
axelrose13
PostPosted: Tue Apr 05, 2011 4:03 pm Up
ty mate if its just the setup then thats fine will get them to sort it, was just worried was ripped off with axel as bad as one taken off van
a rose
PostPosted: Tue Apr 05, 2011 4:06 pm Up
without actually touch the axle no one can tell Laughing
there is always a chance to go wrong when fitting srap yard's part
brimbo
PostPosted: Tue Apr 05, 2011 4:45 pm Up
If you still have the invoice on the axle, check it for any kind of guarentee. I had one fitted today and there's a 60day warranty on the part, not exactly a lengthy period but better than nothing !
W-reg 1.4 LX
