Latest: cogeim7
Overall: 17185
Online Now [410]:
Visitors: 409
Today: 38692
Total: 147352605
Forums › The Car › Solved 206 Problems › Front Fog Lights....NO Joyyy :((**SOLVED**
Forum Index › Solved 206 Problems
PostPosted: Wed Apr 06, 2011 1:25 pm Up
mattievrs wrote:
Have you replaced the stalk with the correct front and rear stalk?
No need its multiplexed Wink
Just needs the BSI config tweaking with PPS
mattievrs
PostPosted: Wed Apr 06, 2011 1:27 pm Up
Ahh ok.
Then in my opinion they dont work either because of a poor earth or they arent part of the fog light looms.
NO LONGER ACTIVE ON THE FORUM
PostPosted: Thu Apr 07, 2011 9:39 am Up
MrBSI wrote:
Take the grey plug of the back of each front foglight, turn the front foglights on & see if there's 12 volts at each grey plug using a multimeter.
I already done that,and checked it with multimeter,and the fuse in the F6 is 15M brand new,but there is nooo +12v in any of the 2 plugs Mad
PostPosted: Thu Apr 07, 2011 9:53 am Up
Well they said this before,but no one told me what earthing should I check,the one behind the headlights on each side for the headlights loom,or does the foglight have a seprate earthing??so can you please show it with pics if available??
PostPosted: Thu Apr 07, 2011 9:55 am Up
This is a pic of my cluster,and as you can see I have the 2 fog lights icons on,for the front and back,the front don't work,but the rear is working fine.
So is there something have to be checking inside the car (BSI)fuse or something missing???
PostPosted: Thu Apr 07, 2011 10:10 am Up
and here I used the fuse:
PostPosted: Fri Apr 08, 2011 10:48 am Up
no more comments I see :(...the fogs is doomed..hehe
PostPosted: Fri Apr 08, 2011 11:45 am Up
12 volts at the connector in the fuse box?
PostPosted: Fri Apr 08, 2011 12:44 pm Up
Which connector you are talking about??,because I was thinking of taking out the fuse box tomorrow,and check the wiring that goes for the foglights/lighting loom,but any help from your side would be much appriciated :D,ty
HDiMan
PostPosted: Fri Apr 08, 2011 2:57 pm Up
According to some Peugeot instructions i found on retrofitting foglights the engine bay fusebox needs changing you should have BSM B2 presently fitted and you need to fit BSM No PR 6500.P4
It also says remove F2 fuse on fitting new part if your car is not equipped with an electrical fuel pump ie DW8 ENGINE.
You also need to enable the foglight option in BSI but i think you have already done that
The instructions came from the foglight upgrade part no 9682L4 multiplexed 2002 onwards for non-sport front bumpers but the fusebox part or the stalk (comm 2000 with F &R FOGLIGHTS) isn't included.I got it cheap on ebay to replace some broken foglights,so i haven't done the upgrade myself.
2005/55 Reg 2.0 HDi 3Dr Sport in Aegean blue.
16" 307 wheels refurbished
New genuine silver dials with oil temp gauge now working too!
Rear Spolier,SP lexus rear lights,SP arches,SP bonnet grille,Sp front grille.SP bumper grille.
Locking leather covered glovebox.
Clifford cat 1 alarm
Recaro seats and rear seats trimmed to match.
Headlamp wash almost done
Gti 180 rear bumper
Morette headlights
Gti 180 carbon effect trim
Alloy stubby aerial
Centre armrest
Black alloy tax disc holder
Gti 180 carbon fibre effect door mirror caps
Carbon fibre effect door card pulls
PostPosted: Sat Apr 09, 2011 5:01 am Up
The one where you have slotted the extra fuse in for F6 position.
Is there 12 volts on the metal terminal where the fuse connected?
PostPosted: Sat Apr 09, 2011 10:13 am Up
I will check the number of the fuse box I have fitted now,and match it with the number you gave me,and see if it match or not,thank you for your reply Smile
PostPosted: Sat Apr 09, 2011 10:15 am Up
Yes there is +12v on the metal terminal on the F6 position.
PostPosted: Sun Apr 10, 2011 11:37 am Up
any new Ideas mates??
PostPosted: Mon Apr 11, 2011 10:55 am Up
Can someone who got foglights originally send me a pic of his/her car fuse box which is located in the engine bay??,I would like to see if I got the right fuse box.
Page 3 of 4
