Latest: tbafonso
Overall: 17130
Online Now [190]:
Visitors: 189
Today: 33430
Total: 103619243
Forums › The Car › 206 Talk › Mud flaps - gloss or matt black?
juanfernandes
PostPosted: Fri Apr 08, 2011 12:13 pm Up
I've bought front and rear Peugeot styled mud flaps.
Not sure if I should put them as they are (matt) or colour code them.
Gloss would look better, but the mud flaps aren't rigid plastic, so I think the paint would crack as I put them on.
Also, paint would get damaged really quickly.
Thoughts and examples of both?
Quote::
PostPosted: Fri Apr 08, 2011 12:19 pm Up
Colour code them, if you use the right paint you shouldnt have any problem. Mine have been colour coded for over a year now and there is only very light chips on the inside.
Pugsy
PostPosted: Fri Apr 08, 2011 12:21 pm Up
i've just bought a set and goin leave them as matt, but i bet yours would look good colour coded Very Happy
Pugsy206asw
juanfernandes
PostPosted: Fri Apr 08, 2011 12:34 pm Up
Mike - yeah problem is I have never sprayed anything before.
What is the right paint? I'm sure there must be a how to on spraying - will look into later.
Did you have them onthe car before you colour coded them? Just wondered if I should they harden a bit and keep their shape a bit better?!?
Pugsy - yeah I know
Quote::
PostPosted: Fri Apr 08, 2011 12:49 pm Up
you need to use the plastic base coat,and then the color of your car,with useing sand paper in the first stage before you spray the plastic base coat,then after it dries,you need to use sand paper again,and then spray it with the color of your car,and then leave it to dry,then sand it again,and then spray it with laqur :D,leave it to dry,and you are ready Very Happy
juanfernandes
PostPosted: Fri Apr 08, 2011 12:55 pm Up
Thanks for that. You make it sound so easy!
Quote::
PostPosted: Fri Apr 08, 2011 1:18 pm Up
It'svery easy,just give it time to dry well between each coat and stage Very Happy
drunknmunky
PostPosted: Fri Apr 08, 2011 2:33 pm Up
could you not use flexible vinyl spray just for in case? not sure if it would be colour match but think you can get it in gloss black?
just a suggestion
|SGP|
PostPosted: Fri Apr 08, 2011 4:14 pm Up
Mine look good in pug black, but I didn't add the laquer on. I kinda wish I did, but it still looks good IMO. Nobody notices anyway.
View my car
