Online Now [583]:
Visitors: 582
Today: 119573
Total: 105846153
Forums › The Car › 206 Talk › How Not to leave torsion bar.!.!
Mr_Cellexe
PostPosted: Fri Apr 08, 2011 1:20 pm Up
as does my 12yr old original bar! lol.
PostPosted: Fri Apr 08, 2011 1:38 pm Up
So the anti roll bar bolt is missing, the plug in the centre of the end plate is missing and the washer hasn't been put into the groove either?
Which halfwit did that? Those washers sitting in the grooves are the only things stopping the trailing arms coming off the axle tube.
80brett
PostPosted: Fri Apr 08, 2011 1:59 pm Up
I've lowered worse lol
TORSION BAR LOWERING SERVICE/ www.b-lowered.co.uk
PostPosted: Fri Apr 08, 2011 2:00 pm Up
Worse than my car? Razz
PostPosted: Fri Apr 08, 2011 2:03 pm Up
The Titanic has less corrosion.
80brett
PostPosted: Fri Apr 08, 2011 2:06 pm Up
Yeah mate a lot worse than yours lol
PostPosted: Fri Apr 08, 2011 2:31 pm Up
Seabook wrote:
did any disc axle use brake compensating valves?
If the car has ABS, then no, and that includes drum axles.
PostPosted: Fri Apr 08, 2011 3:15 pm Up
ok, so that means i can fit one even the axle doesn't come with it?
Coolspot
PostPosted: Fri Apr 08, 2011 4:39 pm Up
I have ABS and a brake compensator so i would double check with a garage. I think the newer cars which have ABS and EBFD might not have it. all depends on age IIRC.
(Don't quote me on it but i would check)
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Fri Apr 08, 2011 4:41 pm Up
Laughing
the thing is my car is old and don't have abs,ebc,ebd,abc...etc Laughing
so i will need a compensator valve on the new disc axle (as it is from a 05 gti, it doesn't come with that)
Coolspot
PostPosted: Fri Apr 08, 2011 5:04 pm Up
The 1st picture you posted up shows the brake compensator attached. Also ABS was an option on the XS in 1999 and then standard in 2000.
But as i say the axle on the car shows you have a brake compensator spring but it may have been removed as i can't see clearly if its attached to anything.
l_jacka
PostPosted: Sat Apr 09, 2011 5:05 am Up
Laughing
Yeah its easy dude, you use the compensator valve that is on the car now, once you remove the drum axle you'll know what I am talking about.
If you need any help then drop me a pm Wink
Looking to buy my first peugeot 206
PostPosted: Sat Apr 09, 2011 5:13 am Up
l_jacka wrote:
Laughing
ic, i just need to confirm that it will fit really.
that means one more stuff on the parts list
Coolspot
PostPosted: Sat Apr 09, 2011 5:27 am Up
Yeah it will fit as they are all the same its just it you can get it off the old one Smile otherwise yoir looking at about £60+ depending where you look.
PostPosted: Sat Apr 09, 2011 5:45 am Up
well, the old one seized every year so i might just have to think about that lol
Page 2 of 3
