Online Now [525]:
Visitors: 524
Today: 25146
Total: 142293654
Forums › The Car › 206 Problems › Anti-pollution fault + rattling sound
Robinson
PostPosted: Mon Apr 11, 2011 3:36 am Up
When I start my car (206 XSi, 2003), I get a rattling sound and an anti-pollution fault warning, that goes off after a few seconds. I seem to have lost some power too. The rattle seems to disappear at higher speeds, although that may be because the noise of everything else is drowning it out.
Any idea what this is? Do I need a new CC, or my CC cleaned, or something like that?
PostPosted: Mon Apr 11, 2011 3:38 am Up
A new cat is probably needed, would explain the rattle. Get the fault codes read and go from there.
Robinson
PostPosted: Mon Apr 11, 2011 3:41 am Up
Can I just phone any old garage for that, or will I need to go to a dealer?
PostPosted: Mon Apr 11, 2011 3:43 am Up
Most garages should be able to read the codes.
Peugeot will charge in the region of £60 and independant garages £20-40.
Or buy a hand held scanner for £30ish and you can use it yourself.
It EOBD Cool
Any small garage / mechanic should have a reader to extract fault codes.
16 pin diagnostic socket is behind the dash flap to right of drivers knee, turn the plastic screw with a coin & lift up / unclip the flap.
Robinson
PostPosted: Mon Apr 11, 2011 3:47 am Up
Ok I'll give 'em a call. Thanks very much...
Oh.... one last question: how much can I expect to be charged for a new CC and work to fit it?
PostPosted: Mon Apr 11, 2011 3:49 am Up
Id much rather have a used GENUINE cat then a cheap new aftermarket one Wink
Cat converters are expensive, not sure what engine is in your 206 but they can be up to £400.
Robinson
PostPosted: Mon Apr 11, 2011 3:50 am Up
To be honest I have no idea about any of this stuff. If it stops the warning and doesn't rattle, I'll be happy.
Robinson
PostPosted: Mon Apr 11, 2011 6:56 am Up
Does engine make a difference? It's an 1.6 XSi. Taking it to the garage tomorrow. Brakes need looking at in any case. It's going to be an expensive week Shocked .
