Latest: Kifi69
Overall: 17183
Online Now [953]:
Visitors: 952
Today: 119271
Total: 144747274
Forums › The Car › 206 Talk › How do you remove aircon rad?
Forum Index › 206 Talk
PostPosted: Mon Apr 11, 2011 5:14 am Up
Mines bit like a banana and middle don't look health Laughing
Ideally I want to remove for time being and reinstall at later time, how do I go about it? I'm bit unsure about aircon with all it's gasses etc
Thanks ben,
PostPosted: Mon Apr 11, 2011 5:15 am Up
Go get it ungassed first. Then just undo the pipes going into it. IIRC. Can't fully remember though.
(Although if there is no gas in it and you are sure, then just go for it. Smile )
PostPosted: Mon Apr 11, 2011 5:19 am Up
I used bolt cutters Rolling On The Floor Laughing
Cut the pipes (after safely removing the gas) but then again I didn't need to reuse it Razz
Mr_Cellexe
PostPosted: Mon Apr 11, 2011 5:25 am Up
you'll be fine venting that gas to air (mind the lubricant - oily substance). just do it gently.
after that just chop everything out and hope you dont want to reuse it! lol
PostPosted: Mon Apr 11, 2011 5:28 am Up
Just accidently let the gas out, accidents do happen with bolt cutters Laughing
Mr_Cellexe
PostPosted: Mon Apr 11, 2011 6:04 am Up
you can let it out on purpose. R134A is used in aerosols and even airsoft guns!
its being replaced by HFO 1234 in newer cars anyway
PostPosted: Mon Apr 11, 2011 9:35 am Up
Nice one cheers guys,
One thing, if it don't work does that mean it's out if gas?
(haven't tested it yet)
PostPosted: Sat Apr 16, 2011 12:58 pm Up
How Do I go arOund getting it out without cutting pipes?
I have all the pump and pipe work loose, just the pipes that go into car holding it in place now,
Mr_Cellexe
PostPosted: Sat Apr 16, 2011 1:37 pm Up
its a pain in the a**e to remove completely. engine out really then it becomes easy!
PostPosted: Sat Apr 16, 2011 3:33 pm Up
I'm in process of taking that out too lol, just wanted aircon out the way ideally without cutting it, Sad
Oh well.
PostPosted: Sun Apr 17, 2011 10:07 am Up
Got it out in two bits, undone the bolt and a tiny pfft that was it, was empty lol
Mr_Cellexe
PostPosted: Sun Apr 17, 2011 10:34 am Up
the entire system? without cutting it to pieces? HOW TO please! lol.
PostPosted: Sun Apr 17, 2011 11:51 am Up
Yer no cutting lol
Well two pipes still in car thats it as not moved them yet, but got pump rad and most of it out just the two pipes into car left ATM,
Took Two bolts to remove it, one that's on the pump and one that's on the tank attached to rad.
PostPosted: Sun Apr 17, 2011 12:52 pm Up
So you've removed the pump...have you got a shorter belt fitted now?
PostPosted: Sun Apr 17, 2011 1:05 pm Up
No I'm currently removing everything including engine ATM bit by bit, the rad I have is naff as in Pic abOve, unsure if to get short belt or to get new rad yet when it all goes back in tbh
