Latest: Beduff1977
Overall: 17134
Online Now [311]:
Visitors: 310
Today: 112518
Total: 107293267
Forums › The Car › 206 Problems › edited
edited
shellis
PostPosted: Tue Apr 12, 2011 12:11 pm Up
edited
shellis
edited
PostPosted: Tue Apr 12, 2011 12:25 pm Up
block coolant pipe/ radiator maybe? are all the pipes and radiator warm after a run?
NA engine was under negative pressure so i doubt it would cause the coolant to blow out. i could be wrong though
punk
PostPosted: Tue Apr 12, 2011 12:32 pm Up
Are you blowing smoke? I don't want to make anyone suck eggs have you checked the oil cap for mayonaise? Thats usualy a given sign of a blown headgasket. Also pop out your themostat and make sure it opens and closes properly.
PostPosted: Tue Apr 12, 2011 12:33 pm Up
There's also no water mix in the oil as i check the oil cap and dipstick regularly anyway is it cylinder pressure escaping directly into the water perhaps?
Wink
benb
PostPosted: Tue Apr 12, 2011 12:39 pm Up
blue smoke from the exhasust and check the oil it may seem watery thats 2 ways of checking a blown head gasket
1.1lx 2000 plate
PostPosted: Tue Apr 12, 2011 12:43 pm Up
or just do the compression test?
i always wonder how much they charged
shellis
PostPosted: Tue Apr 12, 2011 2:36 pm Up
edited
shellis
PostPosted: Tue Apr 12, 2011 2:38 pm Up
edited
shellis
PostPosted: Tue Apr 12, 2011 2:39 pm Up
edited
shellis
PostPosted: Tue Apr 12, 2011 2:41 pm Up
edited
Indigo_GTI
PostPosted: Tue Apr 12, 2011 3:13 pm Up
my 106 does the same. a diesel engine headgasket going is not as bad news as you think, unlike a petrol. i've been running over 3k miles on mine and its still working fine, just bubbles away. just keep the coolant topped up
shellis
PostPosted: Tue Apr 12, 2011 3:23 pm Up
edited
shellis
PostPosted: Tue Apr 12, 2011 4:24 pm Up
edited
punk
PostPosted: Wed Apr 13, 2011 3:04 am Up
Mate if you are from Birmingham, Try Alum Auto spares, It is around the corner from me, great bunch of lads, if they don't have one they will get one ordered in, usually same day, if not next. They are roughly around 20-30 quid.
