Posted: Sat Apr 02, 2011 2:52 pm |
You seem pretty confident with it so you shouldn't need luck. Have you already got the relay? No point dismantling till you get one. I just checked Maplin and they don't list them
Posted: Wed Apr 13, 2011 2:18 pm |
hiya soz i havent got back to you guys sooner. bloody kids!!!! anyway when i took the bsi off from the fuse box i discovered the black connection is corroded so its port on the bsi. what do i do now am guessing that means summit more serious??
cheers
Posted: Wed Apr 13, 2011 2:22 pm |
Electrical contact cleaner, and clean it up
Posted: Wed Apr 13, 2011 2:39 pm |
even if the plastic around the pins is melted??
Posted: Wed Apr 13, 2011 3:11 pm |
right i have just put the bsi back into the car and now its not starting. is it me or is this car just getting worse???
Posted: Wed Apr 13, 2011 4:08 pm |
Does it turn over but not fire?
Or do nothing?
Posted: Thu Apr 14, 2011 2:00 am |
turns over but the engines not kicking in. omg i think i may have killed it. r.i.p pug
Posted: Thu Apr 14, 2011 1:27 pm |
Make sure you've onnected the immobliser back up
Posted: Thu Apr 14, 2011 1:46 pm |
what does it look like so i know that i have??
Posted: Thu Apr 14, 2011 1:53 pm |
Just make sure you've plugged all the wires in right
Posted: Thu Apr 14, 2011 2:09 pm |
right i have checked all the wires. now what ?? its still not working
Posted: Sat Apr 16, 2011 3:24 am |
right it doesnt fire, the right indicator works and so do the hazards but now the left wont do anything no clicking or lights, but it does work as a hazard??
Posted: Thu Apr 21, 2011 4:19 pm |
hi
just to let you know i di exactly as you guys sed and pulled out the bsi and stalks. i dusted it all and put it back in while i shopped for relays. it has started to work again. probably means am gonna have to do this every week. silly thing. only my radio wont work?? it wont switch on or anything, at least before half way through your journey it used to spring into life all of sudden. now it does nothing?? any more ideas.
