Latest: Kifi69
Overall: 17183
Online Now [308]:
Visitors: 307
Today: 148996
Total: 144608629
Forums › The Car › 206 Problems › STOP warning light?
STOP warning light?
rudebwoi93
PostPosted: Fri Apr 15, 2011 11:51 am Up
Hey guys, my sister just came home saying that a stop warning light keeps flashing on the dash when shes driving and sometimes when shes pulled up.
We went straight back out and turned the car on and sure enough the engine turned over and on came the red flashing warning light saying STOP.
I also noticed that it sounded like a hoover had just been started underneath the bonnet, but a lot louder. Is this related? If not, what is it the fan kicking in or something?
Cheers guys!
-Dave-
PostPosted: Fri Apr 15, 2011 11:52 am Up
Trade Rating: +36
Would need the code's read I would have thought.
Ex 206 Owner.
rudebwoi93
PostPosted: Fri Apr 15, 2011 11:55 am Up
Codes read? :S It's a warning light that reads S T O P in red under the speedo bits and it flashes... Then there's the hoover sound... :S
PostPosted: Fri Apr 15, 2011 11:58 am Up
There will probably be a fault code registered. You need to get the codes read so that you can identify the problem, then get the code reset so that it doesn't keep warning you
rudebwoi93
PostPosted: Fri Apr 15, 2011 12:01 pm Up
How do I get this fault code read? Does this mean that its not anything serious? Just something going a bit stupid with the computers/an overeactive warning light?
-Dave-
PostPosted: Fri Apr 15, 2011 12:03 pm Up
Trade Rating: +36
The Stop sign can appear for a few reason's but it generally mean's something is wrong, In order to see what's wrong you get the code's read or at least take it to a garage.
Ex 206 Owner.
rudebwoi93
PostPosted: Fri Apr 15, 2011 12:09 pm Up
Ahh I see. It seems like its a dodgy connection or something related to the fan, because I went out and turned it over again for the 3rd time now, and the light wasnt there and neither was the loud fan noise. I think it's something shorting or somethnig dirty or dodgy thats telling the fan to go nuts. Very intermittent as I've never noticed it until now and now its gone again Neutral
PostPosted: Fri Apr 15, 2011 12:10 pm Up
STOP means stop funny enough
Brake fluid level, or your engine is fooked Laughing
PostPosted: Fri Apr 15, 2011 12:11 pm Up
THis could be a simple fix....Have you check you brake fluid? If it is low the stop light will flash when you are driving.
If low you will need to top using DOT 4 but all so check for leaks as well around the wheels
rudebwoi93
PostPosted: Fri Apr 15, 2011 12:15 pm Up
Its stopped now though mikey and addaz? I'll check the brake fluid level, whats DOT 4? Wouldnt normal brake fluid do..?
PostPosted: Fri Apr 15, 2011 12:21 pm Up
DOT 4 is the brake fluid and you should use that
lofty
PostPosted: Fri Apr 15, 2011 1:09 pm Up
Does the engine temp rise when driving? The fan might not be kicking in and so its overheating.
Mine recently did this as the wiring at the front near the fan was corroded.
Its fine now.
(Touch wood).
206 GTI
Nimrods
SP Grille
Cargo Net!
Leader Team: Tivoli GTI
Leader Team: Cargo Net
Snowboard & Bindings For Sale
PostPosted: Fri Apr 15, 2011 2:43 pm Up
What He Said
Amazing how many people dont bother to pay attention to it though Rolling Eyes
I smell a cooked engine & new head gasket Laughing
rudebwoi93
PostPosted: Sun Apr 17, 2011 11:29 am Up
Its fine now.
(Touch wood).
Just popped out quickly. 5 minutes driving, pulled up 5 mins idling, warning light comes up. After another 5 or so mins it goes away. 5 minute journey home and dad thought to check temperature. Engine temp was above the 90 C mark and opened the bonnet and the heat was crazy for such a shirt journey! Here I am just spotted this post and you come out with that lol! It sounds right to me as it's the same thing my dad reckoned too Very Happy
How did you fix it in the end?
