Online Now [318]:
Visitors: 317
Today: 36468
Total: 138771666
Forums › The Car › 206 Problems › Rear axel bearing?
Rear axel bearing?
ukskater01
PostPosted: Mon Apr 11, 2011 1:32 pm Up
My mechanic friend looked at my rear suspension today and said I might need a new rear axel. He's Turkish and doesn't speak very good English, from what I could understand my bushes are knackared and my axel bearings are worn aswell.
I phoned my local motor spares shop who said they didn't low what axel bearings are and said I must mean wheel bearings, is this right?
Thanks for your time
PostPosted: Mon Apr 11, 2011 1:35 pm Up
No they are different to wheel bearings.
l_jacka
Wheel bearings are completely different from Axle bushes/bearing
Wheel bearning is easy to do, Axle bearing/bushes is a bit complicated
I think you friend meant Axle bushes/bearing, Go and ask him again, is it wheel bearing or the axle bearing/bushes
Looking to buy my first peugeot 206
PostPosted: Mon Apr 11, 2011 1:37 pm Up
no.
axle bearing is on the trailing arm, one outer bearing and one inner bearing, plus oil seal as well.
bush i presume you mean the 4 rubber bush between the axle membrane and the chasie.
wheel bearing are on the hubs.
phone the pug dealer and they will give you the right parts
ukskater01
PostPosted: Mon Apr 11, 2011 1:42 pm Up
Thanks for the quick replies, is it an easy job to replace the bush, axel bearings and oil seals? Is there anything else worth replacing while i'm at it?
Thanks again
PostPosted: Mon Apr 11, 2011 1:50 pm Up
not hard, but is time consuming.
do a search. there is probably more than 100 threads about rear axle in these 2 months!
Schumi
PostPosted: Fri Apr 15, 2011 12:16 pm Up
Hi. I'm Turkish also. I can help to you for translation.
2005 206 RC RED
ukskater01
PostPosted: Fri Apr 15, 2011 2:23 pm Up
Thanks for the offer but I took it to his cousin who changed what I beleive to be the bush and tracking arm
cheers
PostPosted: Fri Apr 15, 2011 2:45 pm Up
Starting to boil my p**s the amount of times this same bloody " rear axle bearing " question gets asked on here Twisted Evil
ukskater01
PostPosted: Sat Apr 16, 2011 1:36 am Up
I wasn't sure what was exactly wrong, I did do a search but everyone jumps on the "change the whole axle" bandwagon, thanks for eveyones help
AX-Rated
PostPosted: Sat Apr 16, 2011 2:47 am Up
Just done a monster How To on this very job.
Black 03 GTi
