Latest: S2cgm
Overall: 17178
Online Now [212]:
Visitors: 211
Today: 72448
Total: 137501707
Forums › The Car › 206 Problems › 180 problems
180 problems
4ndy180
PostPosted: Tue Apr 19, 2011 5:42 am Up
4ndy180 wrote:
Andy180 wrote:
wheres the oil leak coming from? if its from the oil filter it could be the oil filter housing a common fault on 180's iirc, only one id pay to have fixed is the 1st gear judder as it sounds like this flywheel problem most 180s suffer with the rest of the jobs you could easily do yourself.
Yes that's were I saw the oil dripping from when I had a look yesterday. Where best place to buy the housing if that is the case?
The main dealers seem to be praised hell of a lot on here whereas on all my other cars Nissan, SEAT, FIAT, Subaru and Toyota the dealers were useless. Time will tell I guess as the car may need to go in for the flywheel/clutch replacement
PS, sorry about ripping your username, didn't realise Andy180 was taken. Cool username tho, lol Laughing
180 judder is doin my nutt in, lol
PostPosted: Tue Apr 19, 2011 5:47 am Up
replacing a flywheel+clutch would probably cause more that your 180gti worth.
best bid is get the flywheel skim+balance
Andy180
PostPosted: Tue Apr 19, 2011 6:21 am Up
you don't need the actual housing its just the seal you need i got mine from peugeot don't think it was that expensive.
GTI 180
MissGTi180
PostPosted: Tue Apr 19, 2011 6:33 am Up
Mines had an oil leak for a couple of years really should change the filter at some point haha
www.facebook.com/mel206
Big_Rich180
PostPosted: Tue Apr 19, 2011 6:51 am Up
You havnt changed the oil filter in a few years? Confused
4ndy180
PostPosted: Tue Apr 19, 2011 9:30 am Up
Do you mean the seal ? The filter should be changed as part of a regular service Wink
4ndy180
PostPosted: Tue Apr 19, 2011 9:36 am Up
Andy, Any idea on part number?
PostPosted: Tue Apr 19, 2011 11:37 am Up
Cross your fingers the horn issue isnt the com2000 unit as there mega money on the GTI 180 thanks to the ESP system Wink
A 180 should have twin tone horns factory fitted on the same bracket Wink
Andy180
PostPosted: Tue Apr 19, 2011 2:46 pm Up
I think the part number may be 46497 thats what written on the packet ive got anyway.
GTI 180
4ndy180
PostPosted: Wed Apr 20, 2011 1:36 am Up
Ok, next question is how to tell if the horn is a com2000 unit. How hard can it be, its only the horn Shocked .
If need be couldn't I just re wire my own horn ?
4ndy180
PostPosted: Wed Apr 20, 2011 1:41 am Up
Big_Rich180 wrote:
4ndy180 wrote:
Just bought a 180 and have afew faults:
Rear disks badly pitted and h/brake not holding
Oil leak
Horn not working
Judder in 1st gear when setting off
Can anyone help, advise if these are common ?
Take it back to the garage.....unless it was a private sale.
its not from Mansfield is it??
Bought car private from Doncaster Smile
PostPosted: Wed Apr 20, 2011 3:38 am Up
check all the wiring first, if all wire is fine and the horn is working with external power, that=fault com2000
PostPosted: Wed Apr 20, 2011 9:16 am Up
You can BODGE it if you want.
4ndy180
PostPosted: Wed Apr 20, 2011 3:21 pm Up
Don't do BODGE ! DOH!!!
I'm a skilled engineer by trade.
4ndy180
PostPosted: Tue Apr 26, 2011 8:54 am Up
OK, update. Found out that the horn was down to faulty wiring, removed cleaned connections and now works fine Smile
Page 2 of 3
