Posted: Wed Apr 20, 2011 10:22 am |
myt be a stupid question but have you definitely taken the washer out, cant really see from the second pic?
Posted: Wed Apr 20, 2011 10:43 am |
Yeah I have removed the washer it's not obvious in the picture.
Sucks about removing the arms don't want to go there as I won't have a clue what I'm doing not sure what to do about it..
Posted: Wed Apr 20, 2011 10:51 am |
*facepalm*
Sir just knock the bar DRIVERS towards passengers
Then report back
| Team Impossible Possible
Posted: Wed Apr 20, 2011 10:53 am |
Still seized thought they could only go out one way anyway?
Posted: Wed Apr 20, 2011 10:57 am |
| Harry wrote: |
Still seized thought they could only go out one way anyway? |
Do you even read my posts?
You can knock it out that way
But you can take the torsion bar out of the axle if you do (as in hold it in your hand off the car)
Posted: Wed Apr 20, 2011 11:00 am |
I had to resort to using a hydraulic ram between a bolt in the torsion bar and a steel stanchion holding the workshop up!
Not exactly suitable for the diy-er tho!
You are beating it from the right side aren't you?
| I've got to start using this site more! Seeing as I seem to do nothing but sell, break and fix 206's! | |
Posted: Wed Apr 20, 2011 11:10 am |
| Addaz wrote: |
| Harry wrote: |
But you can take the torsion bar out of the axle if you do (as in hold it in your hand off the car) |
Read yes, fully understand the concept not 100%
Just tried both sides again and it's not budging tbh I probably just suck :/
Was mainly hitting it from passengers to drivers side, the top one was so easy I don't understand how this one isn't
Posted: Wed Apr 20, 2011 11:11 am |
Mine was the same
Bottom was the hard one
Bearings arent hard to replace tbh, and if you 100 percent cant get it out, just move the arm
Posted: Wed Apr 20, 2011 11:18 am |
How would you go around replacing them and how much are they? Also would the arb have to be removed for your method? I'm thinking not but if it is my mechanical logic has failed
Posted: Wed Apr 20, 2011 11:22 am |
Yes it would if you wanted the arm to come off
£70 odd for both sides, and wee wee easy
Posted: Wed Apr 20, 2011 11:24 am |
Why is the arm moving on mine so much if the arb is still connected then
Think you should have a road trip to mine and help me I will cover costs
Posted: Wed Apr 20, 2011 11:31 am |
because the anti-roll are only pressed onto the end plate. they are not held by any bolts.
Posted: Wed Apr 20, 2011 12:06 pm |
Put the other torsion bar back, with the washers and bolts and try the seized bar again. This will help stopping the arm from coming off.
Posted: Wed Apr 20, 2011 1:19 pm |
Well now I have broke my 4lbs hammer
I would do that steve but I had to chisel them out so currently waiting for some on order from pug.
Don't know what the next call is, maybe get a garage a have a go at it I know I would probably do more damage than good removing the arm I normally do.
Posted: Wed Apr 20, 2011 1:22 pm |
| Harry wrote: |
Estwing make the best hammers if your looking for a replacement & want quality
