Online Now [101]:
Visitors: 100
Today: 2750
Total: 104975793
Forums › The Car › 206 Problems › axle bush
axle bush
PostPosted: Wed Apr 20, 2011 3:20 pm Up
those 4 rubber bush between the axle and the car bottm; how on earth you can remove them? Laughing
tried using a sliding hammer but won't bugger seems that the rubber bit has absorbed all the force lol
PostPosted: Wed Apr 20, 2011 3:25 pm Up
Cut them out...
80brett
PostPosted: Wed Apr 20, 2011 4:56 pm Up
i got em out with a socket
TORSION BAR LOWERING SERVICE/ www.b-lowered.co.uk
PostPosted: Thu Apr 21, 2011 7:36 am Up
a socket? how?
