Forums › The Car › 206 Problems › axle bush |
Posted: Wed Apr 20, 2011 3:20 pm |
those 4 rubber bush between the axle and the car bottm; how on earth you can remove them?
tried using a sliding hammer but won't bugger seems that the rubber bit has absorbed all the force lol
Posted: Wed Apr 20, 2011 3:25 pm |
Cut them out...
Posted: Wed Apr 20, 2011 4:56 pm |
i got em out with a socket
Posted: Thu Apr 21, 2011 7:36 am |
a socket? how?
