Online Now [82]:
Visitors: 81
Today: 4946
Total: 116958976
Forums › The Car › 206 Problems › are all driveshafts the same size
lexie_2oo5
PostPosted: Wed Apr 20, 2011 3:35 pm Up
hi folks,i replaced the driverside driveshaft on my sons 1999,1.1 motor ,4 weeks ago as it was badly cracking on full lock.that driveshaft did exactly the same and i know that the shaft was ok post installation and started to doubt wether they are the same size.this week i aquired another shaft from a breaker and it looked exactly the same.on fitting the shaft, the car on full righthand lock it is now rubbing the inside of the steel wheel(where the balancing weights would be located)and the trackrod end...have i reassembled correctly....i think i have...or is there a few driveshafts that have different dimensions.tia ps,it drives ok apart from this.
come on NI
PostPosted: Wed Apr 20, 2011 9:30 pm Up
They are different sizes.
iainlovatt
PostPosted: Thu Apr 21, 2011 2:28 am Up
what model did it come off? the 1.1 and 1.4 are the same! are you sure it was the driveshafts and not the CV joints? how bad were the gaiters?
(My Garage)
PostPosted: Thu Apr 21, 2011 4:56 am Up
1.6 are smaller
1.6 16v are even smaller
Talking about the short driveshaft passenger side
lexie_2oo5
PostPosted: Thu Apr 21, 2011 7:16 am Up
this is the long passenger side,when the car was bought ,i noticed that the cv was cracking although the boot was in perfect condition ,so i got a replacement shaft and the same problem persisted.so i then got another out of a 1.1 and this one on full righthand lock is rubbing the wheel rim on the trackrod end,i am baffled as i am sure it is the correct shaft.HELP!!!!
come on NI
PostPosted: Thu Apr 21, 2011 7:18 am Up
Did you do up the 11mm bolts tight? That hold the shaft bearing in?
lexie_2oo5
PostPosted: Thu Apr 21, 2011 9:10 am Up
yep 11mm bolts fully home,lower arm balljoint in ok,trackrod arm in ok.didnt put new lower arm nut and bolt in though.could this be the cause?
come on NI
