Online Now [422]:
Visitors: 421
Today: 17585
Total: 142161776
Forums › The Car › Solved 206 Problems › radio cuts out!!
radio cuts out!!
perry89
PostPosted: Fri Apr 22, 2011 1:09 am Up
hey all,
just wondering if anyone could help, ive replaced my standard car stereo with a sony head unit. everytime i go to turn it up past say... 25 it will just cut out and restart and keep doing so, untill i turn it down again. tried putting my mates stereo in and having the same problems. the standard radio worked fine so im not sure what the problem is, done some research and results show it may be: faulty wiring, bad earthing or i need a power cap? anyone else have a clue? lol
any help would be appreciated
thx
abc
Seb
PostPosted: Fri Apr 22, 2011 1:40 am Up
Staff - Seb
www.206info.co.uk/Foru...=5472.html
"Q: My radio is not saving settings or is turning off at high volumes, what is wrong?
A: You need to change the red and yellow wires around at the back of your head unit..."
Ash
PostPosted: Fri Apr 22, 2011 3:22 am Up
Laughing
ukskater01
PostPosted: Fri Apr 22, 2011 5:49 am Up
Try swapping the wires but it sounds like there isn't enough current going to the stereo, get a multi meter and see what volts and amps your getting when plugged in with it on a low volume and then how much it has when it cuts out, could be the battery
perry89
PostPosted: Wed Apr 27, 2011 11:18 am Up
cheers people, swapping the wires worked a treat, cheers for the feedback Smile
abc
perry89
PostPosted: Wed Apr 27, 2011 11:26 am Up
nice guide btw ash, learned quite alot there lol cheers
abc
irishjimuk
PostPosted: Mon Aug 15, 2011 2:00 pm Up
had the same problem, found this thread, swapped red & yellow. fixed!! thanks
yotsimitsu2
PostPosted: Sun Mar 16, 2014 8:47 am Up
Seb wrote:
http://www.206info.co.uk/Forums/viewtopic/t=5472.html
THANKS A BUNCH>>> WORKED PERFECTLY.
