Posted: Fri Apr 22, 2011 9:16 am |
no unforunately not looks like a recovery to my nearest pug dealer after easter which will go down great with the missus
Posted: Fri Apr 22, 2011 9:24 am |
Id be tempted to try a replacement transponder aerial from a scrapyard first.
Make sure it doesnt rattle when you shake it.
Posted: Fri Apr 22, 2011 9:29 am |
Another question would an autolock company be able to come and do this rather than the cost of recovery
Posted: Fri Apr 22, 2011 9:31 am |
Changing the transponder aerial is simple diy.
Peugeot Planet is the best thing to scan it with.
An auto locksmith should be able to sort the immobiliser out.
Posted: Fri Apr 22, 2011 9:34 am |
thx for your help so far what connector do i need to connect this car up to check it
If its a lexia3 I cant make that im a HW tech but that s beyond me on a easter weekend
Posted: Fri Apr 22, 2011 9:36 am |
The diagnostic socket is behind the flap by the drivers right knee, turn the plastic screw with a coil then lift up / unclip the flap.
You should have already seen the diagnostic socker if you have been in the cabin fuse box
The transponder aerial is just a simple connector plug
Posted: Fri Apr 22, 2011 9:43 am |
yes ive had the transponder off no problems and reseated, looks like a autolock man on Tuesday, Cant see what happened parked up outside home last night locked fine came outside today and nothing, what a nightmare on good Friday anyway thx for all the tips, Just a pity couldnt get it away the missus is well Pi**ed at me, Enjoy the rest of your weekend
If any of you are 360 players visit my website www.360mods.org.uk
Thx again
Posted: Mon Apr 25, 2011 1:44 am |
same thing happened to me when I had my Vauxhall Astra. When I changed the FOB battery, a small chip had dropped on the floor and as a result the car got immobilised.
We then had to get another chip and reprogramme.
I am not saying that this is the case with your car, but it could well be a possibility
