Latest: Stu-mill
Overall: 17131
Online Now [60]:
Visitors: 59
Today: 9621
Total: 104919222
Forums › The Car › 206 Problems › removing this engine mount??
PostPosted: Sat Apr 23, 2011 1:08 pm Up
how does it come off, my old cars one was just a nut and haynes only shows a nut too, but this one has a rubber thing on top Confused
there is a nut under the rubber thing but cant get spanner on it Evil or Very Mad
i have tried pulling rubber thing off but no joy Sad
ben,
cartoonhead
PostPosted: Sat Apr 23, 2011 1:10 pm Up
that needs a 32mm socket or similar
PostPosted: Sat Apr 23, 2011 1:34 pm Up
come again?
looks like a bit of round rubber Confused there is a 16or13mm nut under it ??
XSIcheeseman
PostPosted: Sat Apr 23, 2011 1:50 pm Up
get the rubber bit off the top . l mine was in two bits when i removed it lol i thinks its like a 16 or 17mm but cant really remember , i just airguned it off ( as it was f****d) then screwdriver on the side of hte metal mount' hit it with a hammer so that its un screws .. take it off screw the new one on handtight . put the rest of the mounts back on and tight up with a snap bar .. thats how i done mine at college with my teacher
New and Improved!
New Project
www.206info.co.uk/Foru...51199.html
cartoonhead
PostPosted: Sat Apr 23, 2011 2:02 pm Up
its just a 32mm nut with a bit of rubber on so if you push down on a 33mm socket it will go on and undo it.
feels like its gonna slip/round off the nut but it will grip it enough to undo it.
that nut goes from the rubber to the base which is the threaded nut Smile
PostPosted: Sat Apr 23, 2011 2:14 pm Up
nice one, i got a 32mm that i use for the driveshafts and rear hubs so will smack that on Laughing
couldnt see this in the haynes tho Confused lol
or was on my last car Confused
PostPosted: Sun Apr 24, 2011 9:10 am Up
Tried what u said but it just spins Confused
PostPosted: Sun Apr 24, 2011 9:19 am Up
That rubber thing has a M10 threaded metal insert inside it, you really need to grip it tightly to get it to start to undo.
You might end up destroying it on removal.
PostPosted: Sun Apr 24, 2011 9:23 am Up
Thanks I ripped the top off it trying lol,
Will get some mole grips on it and try again Smile
Thanks Smile
PostPosted: Sun Apr 24, 2011 9:25 am Up
You removing the complete engine mount?
Hope you have the special Peugeot tool Wink
Hammer & decent punch works if your carefull with your aim Cool
PostPosted: Sun Apr 24, 2011 9:30 am Up
Well yer trying to,
Why is it this rubber thing is not in the Haynes and when I too it out my last car it was just a nut and took 2mins lol
PostPosted: Sun Apr 24, 2011 9:34 am Up
Rubber thing isnt fitted on all 206's, just some of them Wink
XSIcheeseman
PostPosted: Sun Apr 24, 2011 10:01 am Up
Air gun it! If your removing it then dont matter if you reck it lol i done it at college air gun the nut off , hammer and screwdriver bang to unscrew it and screw the new one on
New and Improved!
New Project
PostPosted: Sun Apr 24, 2011 10:06 am Up
Lol I have snapon air gun but next door compressor don't reach car lol Laughing
Antknee
PostPosted: Tue Apr 26, 2011 10:12 am Up
out of curiosity im getting quote a bit of a rattle when starting the car up and this engine mount has a gap either side of it between there the bolt is and the rubber things on either side (buffers?), would that cause a loud rattling or is there supposed to be about a 5mm gap either side? because that's how it is on mine atm
