Posted: Sat Apr 23, 2011 1:08 pm |
Posted: Sat Apr 23, 2011 1:10 pm |
that needs a 32mm socket or similar
Posted: Sat Apr 23, 2011 1:34 pm |
cartoonhead wrote: |
that needs a 32mm socket or similar |
come again?
looks like a bit of round rubber there is a 16or13mm nut under it ??
Posted: Sat Apr 23, 2011 1:50 pm |
get the rubber bit off the top . l mine was in two bits when i removed it lol i thinks its like a 16 or 17mm but cant really remember , i just airguned it off ( as it was f****d) then screwdriver on the side of hte metal mount' hit it with a hammer so that its un screws .. take it off screw the new one on handtight . put the rest of the mounts back on and tight up with a snap bar .. thats how i done mine at college with my teacher
Posted: Sat Apr 23, 2011 2:02 pm |
its just a 32mm nut with a bit of rubber on so if you push down on a 33mm socket it will go on and undo it.
feels like its gonna slip/round off the nut but it will grip it enough to undo it.
that nut goes from the rubber to the base which is the threaded nut
Posted: Sat Apr 23, 2011 2:14 pm |
that nut goes from the rubber to the base which is the threaded nut |
nice one, i got a 32mm that i use for the driveshafts and rear hubs so will smack that on
couldnt see this in the haynes tho lol
or was on my last car
Posted: Sun Apr 24, 2011 9:10 am |
Tried what u said but it just spins
Posted: Sun Apr 24, 2011 9:19 am |
That rubber thing has a M10 threaded metal insert inside it, you really need to grip it tightly to get it to start to undo.
You might end up destroying it on removal.
Posted: Sun Apr 24, 2011 9:23 am |
Thanks I ripped the top off it trying lol,
Will get some mole grips on it and try again
Posted: Sun Apr 24, 2011 9:25 am |
You removing the complete engine mount?
Hope you have the special Peugeot tool
Hammer & decent punch works if your carefull with your aim
Posted: Sun Apr 24, 2011 9:30 am |
Well yer trying to,
Why is it this rubber thing is not in the Haynes and when I too it out my last car it was just a nut and took 2mins lol
Posted: Sun Apr 24, 2011 9:34 am |
NorthantsBen wrote: |
Why is it this rubber thing is not in the Haynes and when I too it out my last car it was just a nut and took 2mins lol |
Rubber thing isnt fitted on all 206's, just some of them
Posted: Sun Apr 24, 2011 10:01 am |
Air gun it! If your removing it then dont matter if you reck it lol i done it at college air gun the nut off , hammer and screwdriver bang to unscrew it and screw the new one on
Posted: Sun Apr 24, 2011 10:06 am |
Lol I have snapon air gun but next door compressor don't reach car lol
Posted: Tue Apr 26, 2011 10:12 am |
out of curiosity im getting quote a bit of a rattle when starting the car up and this engine mount has a gap either side of it between there the bolt is and the rubber things on either side (buffers?), would that cause a loud rattling or is there supposed to be about a 5mm gap either side? because that's how it is on mine atm
