Posted: Mon Apr 25, 2011 5:46 am |
Hey
Fiddling around the back of the inlet manifold and I broke a connector that plugs into the back of it.
It's the 1.4 8v engine.
I need to replace the inlet manifold. Can I safely remove the old one and just replace it?
Is there anything I need to do before disconnecting the old one? Do I need to do the replacement immediately or is there a risk of dust and stuff getting in?
Sorry in a bit of rush, hope it makes sense.
Also, can I replace with a version from another model/engine?
Thanks.
Quote:: |
Haven't got a pic but we all know what they look like. |
Being the picky sort - I really hate it when people say this. Yes we all know what it looks like - but we all want to see the condition that yours is in! | |
Posted: Mon Apr 25, 2011 5:48 am |
You will need to replace the gasket.
What you actually broke of?
Posted: Mon Apr 25, 2011 5:49 am |
You didnt break the manifold
As not connectors plug direct into it
Probs a sensor you broke
| Team Impossible Possible
Posted: Mon Apr 25, 2011 6:04 am |
MrBSI wrote: |
What you actually broke of? |
Hope not. Don't think so.
The bit that broke is a connector at the back of it. I'm not sure what it is, it's either a sensor or something.
Posted: Mon Apr 25, 2011 6:06 am |
juanfernandes wrote: |
MrBSI wrote: |
The bit that broke is a connector at the back of it. I'm not sure what it is, it's either a sensor or something. |
Injectors?
Is it on the throttle body?
Posted: Mon Apr 25, 2011 6:07 am |
MrBSI wrote: |
if you remove the inlet manifold from the head then the gasket must be replaced else it will leak.
Posted: Mon Apr 25, 2011 6:14 am |
Addaz wrote: |
MrBSI wrote: |
Injectors?
Is it on the throttle body? |
No it's not the throttle body. The plastic bit after it. There is a plastic bit that has a molded pipe connected to it. The plastic bit that the cable connects to broke.
Posted: Mon Apr 25, 2011 6:15 am |
MrBSI wrote: |
MrBSI wrote: |
if you remove the inlet manifold from the head then the gasket must be replaced else it will leak. |
Really? F*ck! So I need to buy a new gasket and a inlet manifold.
Posted: Mon Apr 25, 2011 6:17 am |
I'm gonna suggest you go get a photo.
Posted: Mon Apr 25, 2011 6:18 am |
Im getting a feeling its one of the stubs for the breather has been snapped off.
Posted: Mon Apr 25, 2011 6:19 am |
Yeh ive got that feeling to
Super glue it back on mate, its simpler
Posted: Mon Apr 25, 2011 6:20 am |
tomd0801754 wrote: |
I'm gonna suggest you go get a photo. |
I will, but I'm not home at the mo.
Posted: Mon Apr 25, 2011 6:24 am |
MrBSI wrote: |
Im getting a feeling its one of the stubs for the breather has been snapped off. |
Yes, that's the word I was looking for. It's a stub but it's not the breather one that is connected to the filter, it's one at the back.
Posted: Mon Apr 25, 2011 6:36 am |
It goes to the brake servo
You wont be going anywhere, you have no brakes now
Posted: Mon Apr 25, 2011 6:37 am |
The stub that broke was behind where my finger is pointing:
The cable connect to here:
