Latest: flipflap
Overall: 17140
Online Now [99]:
Visitors: 98
Today: 27348
Total: 113934532
Forums › The Car › 206 Problems › Oops... Broke inlet manifold
Go to page 1, 2, 3  Next
juanfernandes
PostPosted: Mon Apr 25, 2011 5:46 am Up
Hey
Fiddling around the back of the inlet manifold and I broke a connector that plugs into the back of it.
It's the 1.4 8v engine.
I need to replace the inlet manifold. Can I safely remove the old one and just replace it?
Is there anything I need to do before disconnecting the old one? Do I need to do the replacement immediately or is there a risk of dust and stuff getting in?
Sorry in a bit of rush, hope it makes sense.
Also, can I replace with a version from another model/engine?
Thanks.
Quote::
PostPosted: Mon Apr 25, 2011 5:48 am Up
You will need to replace the gasket.
What you actually broke of?
PostPosted: Mon Apr 25, 2011 5:49 am Up
You didnt break the manifold
As not connectors plug direct into it
Probs a sensor you broke
juanfernandes
PostPosted: Mon Apr 25, 2011 6:04 am Up
Hope not. Don't think so.
The bit that broke is a connector at the back of it. I'm not sure what it is, it's either a sensor or something.
Quote::
PostPosted: Mon Apr 25, 2011 6:06 am Up
Injectors?
Is it on the throttle body?
PostPosted: Mon Apr 25, 2011 6:07 am Up
if you remove the inlet manifold from the head then the gasket must be replaced else it will leak.
juanfernandes
PostPosted: Mon Apr 25, 2011 6:14 am Up
Injectors?
No it's not the throttle body. The plastic bit after it. There is a plastic bit that has a molded pipe connected to it. The plastic bit that the cable connects to broke.
Quote::
juanfernandes
PostPosted: Mon Apr 25, 2011 6:15 am Up
Really? F*ck! So I need to buy a new gasket and a inlet manifold.
Quote::
PostPosted: Mon Apr 25, 2011 6:17 am Up
I'm gonna suggest you go get a photo.
PostPosted: Mon Apr 25, 2011 6:18 am Up
Im getting a feeling its one of the stubs for the breather has been snapped off.
PostPosted: Mon Apr 25, 2011 6:19 am Up
Yeh ive got that feeling to
Super glue it back on mate, its simpler
juanfernandes
PostPosted: Mon Apr 25, 2011 6:20 am Up
I will, but I'm not home at the mo.
Quote::
juanfernandes
PostPosted: Mon Apr 25, 2011 6:24 am Up
Yes, that's the word I was looking for. It's a stub but it's not the breather one that is connected to the filter, it's one at the back.
Quote::
PostPosted: Mon Apr 25, 2011 6:36 am Up
It goes to the brake servo
You wont be going anywhere, you have no brakes now Laughing
juanfernandes
PostPosted: Mon Apr 25, 2011 6:37 am Up
The stub that broke was behind where my finger is pointing:
The cable connect to here:
Page 1 of 3
