Latest: Stu-mill
Overall: 17131
Online Now [32]:
Visitors: 31
Today: 5792
Total: 104915448
Forums › The Car › 206 Problems › Oops... Broke inlet manifold
juanfernandes
PostPosted: Mon Apr 25, 2011 6:41 am Up
Addaz wrote:
It goes to the brake servo
You wont be going anywhere, you have no brakes now Laughing
Thanks. Car is going to be SORN'd at the end of this month.
They worked enough to move the car back into its space Rolling Eyes
Quote::
PostPosted: Mon Apr 25, 2011 6:42 am Up
Yeh, brake master cylinder air feed
Your sir dont have brakes
BTW i think yours is 16v not 8 mate Laughing (as 8v dont have electronic throttle)
PostPosted: Mon Apr 25, 2011 6:49 am Up
The newer ones do Wink
PostPosted: Mon Apr 25, 2011 6:51 am Up
The brakes will still work BUT the servo assistance wont be.
You will need a heavy push on the brake pedal to get the car to stop Wink
PostPosted: Mon Apr 25, 2011 6:57 am Up
Really? I never actually knew that, ta for the info mate
PostPosted: Mon Apr 25, 2011 7:01 am Up
Ive seen them on 2005 onwards TU lumps.
juanfernandes
PostPosted: Mon Apr 25, 2011 11:56 am Up
Thanks for all the replies so far.
So I just need to buy a replacement inlet manifold and a replacement gasket.
Looking on the bay, there are some variations - some from different years. Will any of these fit?
I'm hoping to get one that has that stub in a different place, so it doesn't get in the way.
Quote::
PostPosted: Mon Apr 25, 2011 12:30 pm Up
Pre 2000 will not fit
Ports are: 00-00
Yours are: 0-0-0-0
16 valve will not fit unfortunatly
Im not sure if your throttle body will fit cable operated ones, but it may just look at the hole alignment before purchasing mate
juanfernandes
PostPosted: Mon Apr 25, 2011 2:39 pm Up
Ports are: 00-00
Yours are: 0-0-0-0
Thanks Addaz. Just looking at the bay.
Quote::
juanfernandes
PostPosted: Mon Apr 25, 2011 2:43 pm Up
So can I just go ahead and remove the inlet manifold and leave it off the car until I get the replacement one?
Or is it best to remove it and fit the new one at the same time?
Will it let in dust and stuff if I leave it off?
Quote::
PostPosted: Mon Apr 25, 2011 2:57 pm Up
No harm in leaving it off mate, but may be wise to leave it on till you get a replacement mate
juanfernandes
PostPosted: Mon Apr 25, 2011 3:06 pm Up
Thanks.
Just trying to find one that will fit, but has the stub somewhere else. But the ones on ebay don't show both sides Rolling Eyes
I might just take a gamble on one that looks similar.
Quote::
juanfernandes
PostPosted: Tue Apr 26, 2011 6:33 am Up
Right, if that stub that broke is for the brake master cylinder air feed, can I replace the molded tubing with some silicone hose?
Basically, the reason it broke was because it got in the way, so I was thinking of cutting it down or heating it up and bending it to the right a bit and then use some silicone hosing instead.
Would that work?
Quote::
juanfernandes
PostPosted: Tue Apr 26, 2011 1:05 pm Up
Hmm peugeot wont give out part numbers Mad
Quote::
Lecktorious
PostPosted: Tue Apr 26, 2011 1:31 pm Up
Trade Rating: +59
Use Service Box and give them the part numbers then, they will stop being funny then Laughing
'98 Nile Blue 306 GTi 6
Page 2 of 3
