Posted: Mon Apr 25, 2011 6:41 am |
Addaz wrote: |
It goes to the brake servo
You wont be going anywhere, you have no brakes now |
Thanks. Car is going to be SORN'd at the end of this month.
They worked enough to move the car back into its space
Quote:: |
Haven't got a pic but we all know what they look like. |
Being the picky sort - I really hate it when people say this. Yes we all know what it looks like - but we all want to see the condition that yours is in! | |
Posted: Mon Apr 25, 2011 6:42 am |
Yeh, brake master cylinder air feed
Your sir dont have brakes
BTW i think yours is 16v not 8 mate (as 8v dont have electronic throttle)
| Team Impossible Possible
Posted: Mon Apr 25, 2011 6:49 am |
Addaz wrote: |
BTW i think yours is 16v not 8 mate (as 8v dont have electronic throttle) |
The newer ones do
Posted: Mon Apr 25, 2011 6:51 am |
The brakes will still work BUT the servo assistance wont be.
You will need a heavy push on the brake pedal to get the car to stop
Posted: Mon Apr 25, 2011 6:57 am |
MrBSI wrote: |
Addaz wrote: |
The newer ones do |
Really? I never actually knew that, ta for the info mate
Posted: Mon Apr 25, 2011 7:01 am |
Addaz wrote: |
MrBSI wrote: |
Addaz wrote: |
The newer ones do |
Really? I never actually knew that, ta for the info mate |
Ive seen them on 2005 onwards TU lumps.
Posted: Mon Apr 25, 2011 11:56 am |
Thanks for all the replies so far.
So I just need to buy a replacement inlet manifold and a replacement gasket.
Looking on the bay, there are some variations - some from different years. Will any of these fit?
I'm hoping to get one that has that stub in a different place, so it doesn't get in the way.
Posted: Mon Apr 25, 2011 12:30 pm |
juanfernandes wrote: |
I'm hoping to get one that has that stub in a different place, so it doesn't get in the way. |
Pre 2000 will not fit
Ports are: 00-00
Yours are: 0-0-0-0
16 valve will not fit unfortunatly
Im not sure if your throttle body will fit cable operated ones, but it may just look at the hole alignment before purchasing mate
Posted: Mon Apr 25, 2011 2:39 pm |
Addaz wrote: |
Ports are: 00-00
Yours are: 0-0-0-0
Im not sure if your throttle body will fit cable operated ones, but it may just look at the hole alignment before purchasing mate |
Thanks Addaz. Just looking at the bay.
Posted: Mon Apr 25, 2011 2:43 pm |
So can I just go ahead and remove the inlet manifold and leave it off the car until I get the replacement one?
Or is it best to remove it and fit the new one at the same time?
Will it let in dust and stuff if I leave it off?
Posted: Mon Apr 25, 2011 2:57 pm |
No harm in leaving it off mate, but may be wise to leave it on till you get a replacement mate
Posted: Mon Apr 25, 2011 3:06 pm |
Addaz wrote: |
No harm in leaving it off mate, but may be wise to leave it on till you get a replacement mate |
Thanks.
Just trying to find one that will fit, but has the stub somewhere else. But the ones on ebay don't show both sides
I might just take a gamble on one that looks similar.
Posted: Tue Apr 26, 2011 6:33 am |
Right, if that stub that broke is for the brake master cylinder air feed, can I replace the molded tubing with some silicone hose?
Basically, the reason it broke was because it got in the way, so I was thinking of cutting it down or heating it up and bending it to the right a bit and then use some silicone hosing instead.
Would that work?
Posted: Tue Apr 26, 2011 1:05 pm |
Hmm peugeot wont give out part numbers
Posted: Tue Apr 26, 2011 1:31 pm |
Trade Rating: +59
Use Service Box and give them the part numbers then, they will stop being funny then
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
