Latest: Beduff1977
Overall: 17134
Online Now [241]:
Visitors: 240
Today: 210519
Total: 107612082
Forums › The Car › 206 Problems › How to remove 206 gti 138 manifold ASAP
hubbard89
PostPosted: Mon Apr 25, 2011 7:51 am Up
Having problems removing the manifold off the car and removing the cat of the manifold any advice thanks
PostPosted: Mon Apr 25, 2011 8:15 am Up
You need small hands and long arms. It's a tight squeeze but can be done with the engine in place.
hubbard89
PostPosted: Mon Apr 25, 2011 9:12 am Up
How about putting a 4 to 1 though ? Isit possible putting it in without moving the engine ?
PostPosted: Mon Apr 25, 2011 10:01 am Up
If it's longer than the original you'll struggle. Most go in with the subframe removed.
hubbard89
PostPosted: Mon Apr 25, 2011 2:02 pm Up
Skipped that lol think I'm gonna sell it
mattymj
PostPosted: Mon Apr 25, 2011 3:13 pm Up
I'm sure the 180 has a 4 into 1 so i am sure it's possible
hubbard89
PostPosted: Mon Apr 25, 2011 3:16 pm Up
Yer must be a way I got a but fed up and not nice doing it on ya back either lol
PostPosted: Mon Apr 25, 2011 3:18 pm Up
Tbh, you only have about 8 bolts or more holding the manifold
13mm nuts
Yeh its hard, but worth it Smile
hubbard89
PostPosted: Mon Apr 25, 2011 3:27 pm Up
Ye I got the bolts out the manifold was away from the head just couldn't get it out
Linkpad
PostPosted: Mon Jul 11, 2011 1:13 pm Up
i got long hands is it an easy job and where are the bolts i got a GTI and cant for the life of me see them !!
Boo
meady
PostPosted: Mon Jul 11, 2011 1:18 pm Up
Trade Rating: +45
its easy undoing the bolts from the manifold but its trying to get the manifold out from the engine bay thats the hard part. Its to big to pull down from the engine where the exhaust goes, and withouht removing the top 2 engine mounts and tilting the engine forward you aint pulling it out from the top either Sad
TEAM - I HATE FACEBOOK Smile
Linkpad
PostPosted: Mon Jul 11, 2011 1:39 pm Up
oh bugger thats a pain !! Mines a big 2 litre engine 2
Boo
PostPosted: Mon Jul 11, 2011 2:14 pm Up
It can come out if you move the coolant reservoir off its mounts too.
meady
PostPosted: Mon Jul 11, 2011 3:09 pm Up
Trade Rating: +45
Yeh but you still need to tilt the engine aswell
no_offences
PostPosted: Mon Jul 11, 2011 4:24 pm Up
its doable but fooking arkward
Signature removed due to size
