Latest: tebas93089
Overall: 17179
Online Now [285]:
Visitors: 284
Today: 40299
Total: 138142032
Forums › The Car › 206 Problems › wheel bearing noise
wheel bearing noise
uk174
PostPosted: Tue Apr 26, 2011 7:16 am Up
hi,
have just bought a 03 plate 206 lx 5 door.Great little car ,however have noticed a slight sound on driving,and when took to be checked was told that it was rear n//s bearing ,so had it changed but noise still the same.So had the rear o/s changed too but noise still there!!
Are there any sureshot w2ays to find out which bearing has gone as the garage seems to be suggesting that i need to change all four bearings to be sure
many thaanks
always wanting to learn
Ali_H
PostPosted: Tue Apr 26, 2011 7:18 am Up
Does it happen when moving slow and fast?
kurtis wrote:
PostPosted: Tue Apr 26, 2011 7:24 am Up
For a start a garage should be able to tell if a bearing is worn by the amount of play in the wheel.
Is it a rumbling, knocking, squeaking? Are you sure the noise is a bearing? It might just be road noise coming through the tyres. Might be brakes binding.
