Online Now [346]:
Visitors: 345
Today: 53150
Total: 142197323
Forums › The Car › 206 Problems › Lower arm gaiter, Rear brake compensator , Aux belt needed
cheesedoff
PostPosted: Tue Apr 26, 2011 7:48 am Up
Hi all me again
Just enquiring ,
I have a split o/s/f lower arm gaiter Crying or Very sad
a rear brake compensator that has seized Crying or Very sad
a worn auxiliary drive belt Rolling Eyes
coolant needs replacement time/mileage,engine wiring loose Sad
Anyone know where i can get these parts apart from peugeot Smile
Cheers Wink
somewhere out there sombody\'s laughing....
PostPosted: Tue Apr 26, 2011 7:54 am Up
new wishbone, better to use peugeot stuff otherwise you will need a new one very soon.
compensator valve, did you tried unsezied it? WD40 usually work.
aux belt, again, only use peugeot stuff.
buy cheap buy twice.
O/S/F lower arm gaiter???
Try local motor factors.
cheesedoff
PostPosted: Tue Apr 26, 2011 11:28 am Up
is the lower arm gaiter the same as a wishbone ?? If so peugeot quoted me £132.35
If i knew where the rear brake compensator was i would use the wd40 on it, is it easy to see ?
Peugot quoted me £91.37 !!
Also on the list > the coolant requires replacement time/mileage, the engine wiring loose £48.49???
Will look up local motor factors !
PostPosted: Tue Apr 26, 2011 11:50 am Up
If you want to know about the brake compensator I had similar issues a couple of weeks ago
206info.co.uk/Forums/v...28905.html
I ended up buying a whole unit just for the spring so if yours is seized you could have mine and use the spring from your old one. No idea if the one I bought was seized though as it was second hand.
If you do get a new one don't get one from peugeot they go on ebay for £70 and maybe better from other online shops.
cheesedoff
PostPosted: Wed Apr 27, 2011 4:08 pm Up
my pug is an lx ? will your gti bit be ok ??
How much do you want for it ?
