Latest: Kifi69
Overall: 17183
Online Now [816]:
Visitors: 815
Today: 49736
Total: 144870010
Forums › The Car › 206 Talk › Engine Swap
Engine Swap
Forum Index › 206 Talk
ramtin12
PostPosted: Tue Apr 26, 2011 9:43 am Up
A friend of mine has a 2000 206 gti 138 bhp which was recently rear ended, the damage is mostly cosmetic, and the car is still running fine.
He has offered the car to me for cheap and so I was wondering if it were possible to use his car as a donor and put his engine into my 1999 1.4 LX, and if so what parts would have to be changed?
Kersh
PostPosted: Tue Apr 26, 2011 9:44 am Up
its possible, but its not easy. youd have to swap the engine, suspension and brakes
Member number: 36
PostPosted: Tue Apr 26, 2011 9:45 am Up
Wiring etc
dan_206
PostPosted: Tue Apr 26, 2011 9:49 am Up
Gearbox too.
4th 206 but finally a 180
Kersh
PostPosted: Tue Apr 26, 2011 9:50 am Up
and the badges off the boot Smile
Member number: 36
ramtin12
PostPosted: Tue Apr 26, 2011 9:51 am Up
can see why brakes would need changing, but why suspension? wouldn't that be optional depending on how u would want it to ride?
PostPosted: Tue Apr 26, 2011 9:52 am Up
Hubs are different sizes for the shafts
Dont forget insurance/dvla now Wink
rudebwoi93
If the damage is mostly cosmetic your better off selling your 1.4lx then just repairing the gti. If you've modded the exterior of your 1.4 itd probably still be better to swap over + respray if need be the parts to the gti
Kersh
PostPosted: Tue Apr 26, 2011 9:53 am Up
heavier engine will need the different shocks to compensate.
and GTi suspension is firmer on the rear anyway so you may as well Smile
Member number: 36
Antknee
PostPosted: Tue Apr 26, 2011 9:57 am Up
wouldnt you need to change the ecu etc too?
ramtin12
PostPosted: Tue Apr 26, 2011 10:03 am Up
the 1.4 LX was an ex show car and has had both work done on the exterior and interior; back seats have been removed and replaced with a custom fibre glass box holding 6 12" subs and 5 amps (which can't be removed without damaging the box). And i've just recently spent quite a bit getting everything to look mint again, which why I was wondering about the engine swap.
PostPosted: Tue Apr 26, 2011 10:08 am Up
if you can do it urself then is fine.
bsi, wire loom, engine,ecu, gearbox, front strut, whole exhuast system,
not even sure if the engine mounting point is the same.
ramtin12
PostPosted: Tue Apr 26, 2011 10:16 am Up
Has anyone on the forum put a 2.0 gti into a 1.4, or does anyone know if the engine mounting point is the same?
Antknee
PostPosted: Tue Apr 26, 2011 10:21 am Up
what 1.4 engine is it?
edit: nevermind cant really tell too well on servicebox
ramtin12
PostPosted: Tue Apr 26, 2011 10:25 am Up
1.4 8v
