Online Now [418]:
Visitors: 418
Today: 119731
Total: 142502462
Forums › The Car › 206 Problems › Cooling fan wiring query
Go to page 1, 2, 3  Next
richpowell91
PostPosted: Mon Apr 25, 2011 4:18 pm Up
Hi all, basically ive got the common problem of having part of the cooling fan wiring corroding and turing to dust. Having looked on service box for the part number the only wiring i can find is in the picture below.
There are a few differences between the picture on service box and the wiring on the car.
First one being that where i have circled it and labeled number 1 i have two wires coming from the main wiring and providing an earth.
Second one is at the point ive circled and labeled as 2 i have the main wiring connector where as on the picture it doesnt seem to have one.
The last is that were it is labeled 1 in black on mine it goes into the fuse box yet in the picture it looks different.
Has anyone brought this part from peugeot before and found that these few points are included in the wiring or am i looking at the wrong part on service box.
Just asking on here before i have a wasted 40 mile round trip, so any help would be greatfully received.
PostPosted: Tue Apr 26, 2011 1:46 am Up
Did you input your VIN number at the start when you opened Service Box?
richpowell91
PostPosted: Tue Apr 26, 2011 4:38 am Up
I hadnt done the first time, have just entered it this time and got the same part number but this time with no mention of air conditioning, or the two points that is on my wiring:
richpowell91
PostPosted: Tue Apr 26, 2011 10:36 am Up
Can anyone shed any light on it?
PostPosted: Tue Apr 26, 2011 11:30 am Up
Whats your chassis number?
richpowell91
PostPosted: Wed Apr 27, 2011 5:52 am Up
Sorry didnt see this untill now, ill pm you it thanks
PostPosted: Wed Apr 27, 2011 8:33 am Up
Hi,
The car has a 250w two-speed fan
Wiring Diagram - www.ld-automotive.co.u...xed_l3.pdf
On a side note: You've had your door locks fixed twice, drive belt fixed three times due to slipping off and you accelerator pedal fixed while under warranty. All around 40k miles.
perry081064
PostPosted: Wed Apr 27, 2011 10:04 am Up
Lee wrote:
Hi,
he so damn precise , its scarey Laughing
206 2.0 HDI
richpowell91
PostPosted: Wed Apr 27, 2011 12:39 pm Up
perry081064 wrote:
Lee wrote:
Hi,
You can say that again lol.
richpowell91
PostPosted: Wed Apr 27, 2011 12:43 pm Up
Lee wrote:
Hi,
Thanks for that i notice that those pictures dont show the two points that are also missing on the one on service box, i imagen it wouldnt go into that detail? Would you by anychance know if the part number is correct that i found?
Thanks again
PostPosted: Wed Apr 27, 2011 1:54 pm Up
the diagram matches yours :/
richpowell91
PostPosted: Wed Apr 27, 2011 2:46 pm Up
Sorry should have uploaded this before now. This is the wiring i removed from my car, ive labelled it as i understand it.
1. Relays
2. Cooling fan connector
3. Resistor connector
4. Earth
5. Main connector plug
6. Live feed which clicks into the fuse box.
The points that i was refering to was points 4 and 5. The picture on service box doesnt seem to show these. The query i have is would these be points that the wiring would include but not show them on service box or would these have to be added to the new loom.
perry081064
PostPosted: Wed Apr 27, 2011 3:06 pm Up
im following this thread too, i need to repair the wiring thats corroded at the lower green relay tomorrow.
206 2.0 HDI
PostPosted: Wed Apr 27, 2011 3:16 pm Up
Are you replacing the whole loom then?
They more than likely should be included in the loom
richpowell91
PostPosted: Wed Apr 27, 2011 3:27 pm Up
Im going to check the wires properly tomorrow, was just getting my options sorted so im not held up by this bank holiday weekend.
Thanks again for your help.
Page 1 of 3
