Online Now [114]:
Visitors: 113
Today: 30421
Total: 105003361
Forums › The Car › 206 Problems › do shocks have to settle in?
PostPosted: Wed Apr 27, 2011 4:27 pm Up
Film the noise, or get someone to try and pin point it for you
I may have the same noise, but i just put that down to exhaust, happened after i lowered her more
PostPosted: Wed Apr 27, 2011 4:32 pm Up
yours is just bottoming out Laughing
PostPosted: Wed Apr 27, 2011 4:34 pm Up
Ill try film thw noise and is the anti roll bar easy to adjust incasw it is that?
PostPosted: Wed Apr 27, 2011 4:36 pm Up
13mm hex bolts on the trailing arms
check edward's thread in the DIY section
PostPosted: Wed Apr 27, 2011 4:50 pm Up
Thanks dude ill have a looky first thing in morning
PostPosted: Wed Apr 27, 2011 4:51 pm Up
You need to do the shock bolts VERY (obviously within reason) tight. They is so much pressure on them it's so easy for them to come loose. Exactly the same happened to me and yes it sounded like a knocking noise.
Just tighten them and it should solve it.
PostPosted: Wed Apr 27, 2011 4:53 pm Up
Thanks for youe reply mate, i think this may be what ive been needing to find out
Ill do that asap in morning
Cheers Harry
PostPosted: Wed Apr 27, 2011 5:00 pm Up
Cheers Harry
No worries, very unlikely to be anything else if you have only touched them.
PostPosted: Wed Apr 27, 2011 5:04 pm Up
Hope so
PostPosted: Thu Apr 28, 2011 12:39 pm Up
Now Solved!
Was what Harry said
Nuts needed tightning up as they were not very tight, just that it said on box not to tighten them which confused me
Thanks for everyones help
PostPosted: Thu Apr 28, 2011 12:49 pm Up
that why you need a torque wrench Laughing
PostPosted: Thu Apr 28, 2011 1:21 pm Up
It said on the box not to tighten them? Rolling On The Floor Laughing
PostPosted: Thu Apr 28, 2011 1:22 pm Up
over tighten i guess.
can cause the bush to damage very easily
Ste
PostPosted: Thu Apr 28, 2011 1:26 pm Up
Staff - Ste
Let's hope he tightened them with the car on the floor and not up in the air, otherwise it may be a case of early bush death soon to come o.O
Speaking of which, I still have a set of 180 shocks sat under my bed that I havent yet fitted lol!
The Cars:
PostPosted: Thu Apr 28, 2011 1:30 pm Up
I thought I had tightened mine but they rattled a fair bit so put quite a lot of pressure on them and have been fine ever since Smile
Lazy ste, hardly difficult Wink
Page 2 of 3
