Latest: jackrox1992
Overall: 17186
Online Now [428]:
Visitors: 427
Today: 113591
Total: 148485780
Forums › The Car › 206 Problems › Bigggg Problem!
Bigggg Problem!
Norvvv
PostPosted: Thu Apr 28, 2011 2:27 am Up
Car type in my Sig.
At the moment the problem seems to be in 2nd, 3rd and 4th, if i accelerate fast the car will accelerate for a second to about 2.5 revs on the counter then the car stops accelerating and revs like it's not in gear.
The gear stays in place, however could it be a clutch issue as i've had clutch judder for a while...?
Got a feeling this could be costly...
Seb
PostPosted: Thu Apr 28, 2011 2:30 am Up
Staff - Seb
I can't see your car type as it's not showing a sig. It could well be a clutch issue yes, if you stop pressing the accelerator does it start moving again?
If the answer is yes, your clutch is buggered.
PostPosted: Thu Apr 28, 2011 2:31 am Up
Where's your sig?
Do you not have a problem setting off from stationary? Could be a gearbox issue.
You have disabled your sig from posts.
However for everyones info it is a 2001 1.4lx,
Smile
Norvvv
PostPosted: Thu Apr 28, 2011 2:38 am Up
Haha yeah my bad :L must of done that by accident Smile
When i stop accelerating the revs drop back down and the gear reingages ot the clutch disengages depending on the problem ...
EDIT - Think your sig doesn't appear in you're thread opening post...? Smile
2001 1.4lx
PrePlexed 5 door.
Seb
PostPosted: Thu Apr 28, 2011 2:39 am Up
Staff - Seb
Oh so you mean it actally pops out of gear? Or does it just feel like it? If you slowly lower the revs does the car slowly start moving again?
Norvvv
PostPosted: Thu Apr 28, 2011 2:41 am Up
Kind of i suppose.
Don't know i will have to test when driving again at about 11
PostPosted: Thu Apr 28, 2011 2:46 am Up
What happens if you accelerate in a normal manner?
Norvvv
I didn't really slowly lower the revs I came of ten completely then it goes again yes
2001 1.4lx
PrePlexed 5 door.
Norvvv
PostPosted: Thu Apr 28, 2011 2:50 am Up
It will still do it the majority of the time, only accelerating faster seems to exaggerate it and it will happen lower on the revs. I would have to be accelerating quite slow for it not to happen.
Bassline_Toad
PostPosted: Thu Apr 28, 2011 2:58 am Up
Yeah, sounds like a worn clutch. Had the same problem on mine. Cost around £230 for parts and fitting, However, I got a Sachs racing clutch, which was more expensive.
Bad news mate, it will only continue to deteriorate until you change it.
Good news is you'll really notice the difference when you do Smile
kip_206
PostPosted: Thu Apr 28, 2011 3:01 am Up
Defo the clutch had this on a 306 I had
206 glx 1.6
Norvvv
PostPosted: Thu Apr 28, 2011 3:03 am Up
Cheers boys, kinda glad it is the clutch as i already knew that would need doing eventually with the clutch judder and stuff whereas if the gearbox had gone as well i would of been screwed! :L I know someone who's a manager at a car parts supplies place so they get me 50% off parts so shouldn't be too steep for me! Still lucky payday was today though!! haha
2001 1.4lx
PrePlexed 5 door.
J-Turbo
PostPosted: Thu Apr 28, 2011 3:24 am Up
by the sounds of it the car needs a new clutch and it also sounds like it is going into what is known as limp home mode its when a car's ecu knows that there is a problem and wont let it go too high in revs it sounds like this as you said it wont go over 2.5 revs
hope this helps
ITS NOT IF YOU WIN BY AN INCH OR A MILE WINNING IS WINNING
Twincam007
PostPosted: Thu Apr 28, 2011 5:36 am Up
If it turns out that the gearbox is gone as well, I have one that is in perfect working condition that you can have really chaep.Just want to get rid of the extra bits
Twincam007
