Online Now [1240]:
Visitors: 1239
Today: 302288
Total: 146433534
Forums › The Car › 206 Talk › mfd question?
mfd question?
Forum Index › 206 Talk
dumdum0910
PostPosted: Sat Apr 30, 2011 6:35 am Up
ive got the standard 1 line display . clock date/radio can you change it to the 3 line mfd ? if so is it just a case of swapping the display or is there more involved?
PostPosted: Sat Apr 30, 2011 6:55 am Up
No idea as you havent given the forum a clue of what type of 206 you are asking about Rolling Eyes
How do you expect help if you dont bother to give us some basic information about your car Wink
dumdum0910
PostPosted: Sat Apr 30, 2011 7:00 am Up
ive got a 206 look 1.1 with the display that shows time . date radio info and i want to change it for the 3 line display that shows whats left in the fuel tank etc . is it possible to do this ?
PostPosted: Sat Apr 30, 2011 7:39 am Up
Year of car would help, then it at least helps us to not guess so much.
Yes you can change it but it may involve cutting wires to change the pin locations and you won't be able to have mpg etc as you obviously need the sensors and whatever else is needed to display it.
(+ if yours is preplex it definately won't be able to have mpg)
PostPosted: Sat Apr 30, 2011 8:03 am Up
FFS I give up Rolling Eyes
Im not helping any more in future on threads where people cant be bloody bothered to post the full information of the car in question.
dumdum0910
PostPosted: Sat Apr 30, 2011 9:06 am Up
its a 2003 and its a plexed with the BSi
dumdum0910
PostPosted: Sun May 01, 2011 3:28 pm Up
some must of done this or must no
Lecktorious
PostPosted: Sun May 01, 2011 3:31 pm Up
Trade Rating: +59
Aye there is a 'how-to' if you bothered to use the Search function.
'98 Nile Blue 306 GTi 6
dumdum0910
PostPosted: Sun May 01, 2011 4:30 pm Up
i had a look but didnt no it was called a ppt... what sensors do i need? and were do they go ?
Lecktorious
PostPosted: Sun May 01, 2011 4:34 pm Up
Trade Rating: +59
Do a search FFS.
Edit: Lee - Laughing
THEY SHOULD USE THE SAME PPT-40 CONNECTOR SO WILL JUST PLUG AND PLAY, YOU WILL NEED THE TEMP SENSOR ON THE N/S WING MIRROR AND THEN IF YOU WANT THE TRIP COMPUTER, YOU WILL NEED IT TURNING ON IN THE BSI AND THEN CHECK YOUR COM TO SEE IF THERE IS THE BUTTON UNDER THE CAP ON THE WIPER STALK. IF NOT, YOU NEED A NEW COM
YEAH I KNOW THIS IS IN CAPS, I COULDN'T BE ARSED TO TURN THEM OFF BECAUSE IT IS AS DIFFICULT TO TURN THESE OFF AS NOT SEARCHING, AND THEN CREATING A THREAD GIVING f*** ALL INFORMATION
GOOD DAY.
PostPosted: Mon May 02, 2011 2:57 am Up
If only you had given that information in your first post Wink
As for BSI ALL 206's have them, both non plexed & plexed
dumdum0910
PostPosted: Mon May 02, 2011 3:16 am Up
so what sensors do i need to be able to get mpg ant what ever else the multi display can show? and will the wiring be in the car already?
copey
PostPosted: Mon May 02, 2011 3:47 am Up
has lee just not explained it all in the post above?
02 2.0 hdi d turbo
Lecktorious
PostPosted: Mon May 02, 2011 5:00 am Up
Trade Rating: +59
*clicks watch topic* Laughing
