Posted: Sun May 01, 2011 4:58 am |
got a bad oil leak just found out its coming from the bottom of timing belt cover what can it be and will it be a hard job
Posted: Sun May 01, 2011 5:11 am |
Sounds like either the camshaft or crankshaft oil seal to me. You would need to remove the covers and take a look.
Posted: Sun May 01, 2011 5:17 am |
is it a hard job to do
Posted: Sun May 01, 2011 5:19 am |
Taking the top cover off is ok. Bottom cover is horrible. Need to remove the pulley for the alternator etc from the crank
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
