Online Now [216]:
Visitors: 215
Today: 30896
Total: 143099365
Forums › The Car › 206 Problems › since i installed the sub.
scottsgti
PostPosted: Sun May 01, 2011 10:05 am Up
put my sub and amps in the car today, and now when ever i start the car there is a crackle through the speakers and i can hear the cars engine through the speakers, when ever i accelerate there is a fairly high pitched wine.
which will get really annoying, really fast.
i've cleaned some of the earths i can find, because apparently if there is any s**t on them that could cause it, but it hasn't cured my problem.
cheers.
coopskin
PostPosted: Sun May 01, 2011 10:06 am Up
Trade Rating: +13
have you put the RCA's and the remote wire on opposite sides of the car?
scottsgti
PostPosted: Sun May 01, 2011 10:11 am Up
yep, there both running down opposite sides.
never had this problem in any of my other cars, although i've always changed the headunit. but in my 206 i've just kept the original headunit in, not sure if thats the reason why?
moonstone blue 206 gti 138, sp kit. completely standard
coopskin
PostPosted: Sun May 01, 2011 10:13 am Up
Trade Rating: +13
quite possible, maybe borrow an aftermarket one, hook it up to your system and see what happens
Ash
PostPosted: Sun May 01, 2011 10:16 am Up
I use the standard headunit and I don't have that problem..
PostPosted: Sun May 01, 2011 10:21 am Up
RCA's are squished or not in correctly
Or
Bad earth
PostPosted: Sun May 01, 2011 10:33 am Up
Or
Bad earth
What He Said
Ben.M
PostPosted: Sun May 01, 2011 10:50 am Up
Or
Bad earth
And thats the technical term for it too Wink
Ben.M
glenpring
PostPosted: Sun May 01, 2011 10:51 am Up
how did you manage to rig up sub and amp to standard hd???????? would be quite good to know lol
Bassline_Toad
PostPosted: Sun May 01, 2011 11:05 am Up
Someone I know had this very problem. Turned out, they'd wired it incorrectly. It'll be a small schoolboy error IMO, something like connecting a wrong wire somewhere.
PostPosted: Sun May 01, 2011 11:07 am Up
Speaker wire to phono adapter, costs about £5
scottsgti
PostPosted: Sun May 01, 2011 11:23 am Up
yeah got an adapter, not sure what its exact name is, but it also houses 2 fuses for both my amps.
perhaps it is a silly error, but it will have to wait, because it took hours to do and i aint looking through it all anytime soon haha
i will check the earths and rca's though.
DeadEyePaul
PostPosted: Sun May 01, 2011 12:03 pm Up
I had this exact problem I found a speaker wire that became unsheeved and the exposed wires was touching the cars bodywork. So check all your wires it took me the best part of 2 days before I discovered this! I re-wired the whole setup before I discovered it was just one speaker cable
scottsgti
PostPosted: Sun May 01, 2011 12:15 pm Up
ugghh... knowing my luck that will be whats happened to mine then.
cheers for advice
europug
PostPosted: Sun May 01, 2011 3:15 pm Up
I had this probably turned out my headhunt had a bad earth so a long story to find the problem but thats wot it was drove me mad for ages went to a company who found the fault n fixed it for me the guy was the nuts
