Latest: jackrox1992
Overall: 17186
Online Now [1002]:
Visitors: 1001
Today: 138892
Total: 148290573
Forums › The Car › 206 Problems › grinding gears
grinding gears
colly
PostPosted: Sun May 01, 2011 1:53 pm Up
alright folks looking for abit of advice!!!
when going into 3rd sometimes 4th the gears grinde drives fine but rather annoying!!!
anyone got any ideas what it could be??
the car is a 51 plate gti
cheers
206 gt ayeee
MrrNoName
PostPosted: Sun May 01, 2011 1:56 pm Up
the gear box's are known to be crappy in comparison to fords etc, have you tried letting it sit in neutral for just a split second before changing to the other gear instead of going straight in, that might stop it Smile does in mine lol
could be the gearbox on its way out...
colly
PostPosted: Sun May 01, 2011 2:03 pm Up
yeah sometimes is ok when i leave it for a split second and put it in, mostly 3rd gear thought it might be a linkage or something i dunno!!!
seems to drive fine when in gears so don"t think it is gear box (i hope)
206 gt ayeee
PostPosted: Sun May 01, 2011 2:12 pm Up
Linkages, lack of oil, or synchro
PostPosted: Sun May 01, 2011 4:21 pm Up
Probably just worn synchros. The gearbox doesn't even need to be removed to fix these...if you know what you're doing!
Davels
PostPosted: Sun May 01, 2011 5:04 pm Up
I think my second gear synchro is dying. I get a horrible crunch if I'm high in the revs changing from first, thats why I'm planning on changing my gearbox oil, to hopefully alleviate the problem for a while.
never have a problem changing down because rev matching is second nature after my blip down VTEC days Laughing
cosmicdance
PostPosted: Mon May 02, 2011 1:09 am Up
My gears used to grind from 3rd to 4th when I had a Peugeot 106 and I cured it by simply changing the gearbox oil.
The oil doesn't last forever so becomes ineffective after the recommended service interval change - not sure exactly how many miles off hand.
It's a very cheap fix and even if it isn't this that's the problem it's always good to have fresh oil to prolong the gearbox life.
Very easy to change as well and there are tutorials on this site.
My Peugeot 206 has never crunched gears when changing but I put new oil in to prevent it doing so when I bought it.
Andy
Andy
