Online Now [447]:
Visitors: 446
Today: 65712
Total: 142109145
Forums › The Car › 206 Problems › Torsion bar..
Torsion bar..
Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sat Apr 30, 2011 7:46 am Up
NorthantsBen wrote:
I have cut them before,
Teebag has cut ones too Wink tho car was too low so we raised it up a tiny bit Laughing
How would you go around cutting them? could just grind them not sure if it's the best way though.
PostPosted: Sat Apr 30, 2011 7:48 am Up
if you cut the bump stop it would void the warranty.
better to hit the bump stop than bottoming out the dampers.
PostPosted: Sat Apr 30, 2011 7:51 am Up
Does the car actually have a warrenty? it's nearly 10 years and I wouldn't ever take it to a pug garage anyway.
PostPosted: Sat Apr 30, 2011 7:54 am Up
i though you just install some new dampers Laughing
anyway that doesn't make any difference. hitting the bump stop is better than bottoming out.
PostPosted: Sat Apr 30, 2011 8:21 am Up
Fair enough yeah I have spax ones on would never use the standard dampers this low
PostPosted: Sat Apr 30, 2011 8:52 am Up
Pop them off car then Stanley knife goes through them fine,
PostPosted: Sun May 01, 2011 1:16 pm Up
Seriously, they are there for a reason! Even if you cut them off, and your car will go lower, you'll be hitting metal, which will be worse. Through experience i know your axle will not last.
PostPosted: Sun May 01, 2011 4:50 pm Up
Didn't want to cut them off I'm not completely retarded Laughing
When you look at them they are pretty huge, just wondered if you can shrink them a bit whilst still keeping the rubber stopping force but allow more travel. Didn't know if it would benefit at all.
PostPosted: Sun May 01, 2011 4:51 pm Up
you would just put more force to the piston. there is a reason why the bump stop is that long.
Page 5 of 5
