Latest: Kifi69
Overall: 17183
Online Now [461]:
Visitors: 460
Today: 54283
Total: 144682315
Forums › The Car › 206 Talk › 15" GTi Foudre alloys
Forum Index › 206 Talk
perry081064
PostPosted: Mon May 02, 2011 5:56 am Up
just got some of these but came without the bolts.
... the bolts on my old alloys look too short.
.... can anyone link me to the ones i need please ?
206 2.0 HDI
PostPosted: Mon May 02, 2011 5:57 am Up
They are hubcaps you have in your sig?
You need peugeot alloy ones, they are cheap new
perry081064
PostPosted: Mon May 02, 2011 5:59 am Up
yeah , thats an old pic Laughing
my old alloys was peugeot ones, but the bolt is still too short.
also forgot to ask, the ones off my old alloys are tapered, will i need flat or tapered for these, tried searching but couldnt find any info.
do halfords stock the ones i need ?
206 2.0 HDI
PostPosted: Mon May 02, 2011 6:09 am Up
Flat mate, and i dont think so?
Tapered are for steelies i think
richpowell91
PostPosted: Mon May 02, 2011 6:16 am Up
Ive just broughlt some sirocco alloys and phoned peugeot about bolts they quoted me £2.26 each for bolts with part number 540567
I then asked for a price on a bolt part number i got of servicebox 540565 they quoted me £1.70 each.
When i asked the difference between the two the only difference is the size of the head of the bolt. There both flat seated bolts with a shoulder. 540567 being 17mm and 540565 being 19mm so im going to go with the later and save about £10 in the process.
perry081064
PostPosted: Mon May 02, 2011 6:17 am Up
thanks .
just to confirm :
these are the old ones:
new ones ( well, secondhand lol )
... so only peugeot for the bolts ?
206 2.0 HDI
cartoonhead
PostPosted: Mon May 02, 2011 6:31 am Up
They can also be found Here Wink
PostPosted: Mon May 02, 2011 7:04 am Up
perry081064 wrote:
thanks .
just to confirm :
Exactly the problem when i changed from the same alloys to the Foudre's, Peugeot / Citroen main dealer for the correct flat washer type alloy wheels bolts, there a lot cheaper then you think Wink
perry081064
PostPosted: Mon May 02, 2011 7:26 am Up
thanks all.
will take a run over tomorrow , i hate bank hols Laughing
206 2.0 HDI
PostPosted: Mon May 02, 2011 8:17 am Up
perry081064 wrote:
thanks all.
You original alloy wheel bolts had a 17mm head.
The bolts for the Foudre wheels have a 19mm head.
Make sure the wheel brace is suitable Wink
perry081064
PostPosted: Mon May 02, 2011 9:57 am Up
MrBSI wrote:
perry081064 wrote:
thanks all.
i have one of those braces with 4 different sized heads, hopefully one of those will be the right one.
..... then again, knowing my luck Laughing
mr.bsi is this the right part number for the ones you got ( 540565 ) ?
206 2.0 HDI
PostPosted: Mon May 02, 2011 10:23 am Up
Nope, you need Peugeot / Citroen part number 5405 67 Mounting screw £2.26 each
perry081064
PostPosted: Mon May 02, 2011 10:49 am Up
cheers mr.bsi
20 miles to my nearest dealer so just making sure i get the right ones Wink
i take it becouse they have a flat head, its gives you those few extra mm for a better fitting to the hub.
i ask this becouse i noticed the actual hub thread is slightly ingressed into the hub
206 2.0 HDI
PostPosted: Mon May 02, 2011 11:09 am Up
No idea, thats just the part number for the alloy wheel Peugeot say to use with the Foudre alloy wheel.
You can get them from a Citroen main dealer if there nearer Wink
perry081064
PostPosted: Tue May 03, 2011 8:08 am Up
picked the bolts up this morning, had to call at citroen an peugeot in burton as both didnt have enough Laughing
and thanks mr.bsi , they fit perfect Wink
206 2.0 HDI
