Online Now [1092]:
Visitors: 1092
Today: 203496
Total: 146348266
Forums › The Car › 206 Talk › Crankshaft Pulley 2.0 Hdi
Forum Index › 206 Talk
eddrj
PostPosted: Tue May 03, 2011 12:49 am Up
How can you tell when this needs doin exactly apart from tapping noise ? mine makes tapping noise most of the time.
How often do they need doing had mine done bout 21,000 miles ago would it be due i know these are most common fault with the 2.0 Hdis.
Old car 2000/ 206 2.0 hdi.
cartoonhead
PostPosted: Tue May 03, 2011 1:38 am Up
have you checked your AUX (power steering / alternator ) belt tensioner ?
PostPosted: Tue May 03, 2011 2:12 am Up
if you got the new pully then it won't be at fault again
spud_owen
PostPosted: Tue May 03, 2011 3:08 am Up
youd be suprised how quickly they go replaced mine at start of jan, and it had gone by start of april, proper pug bits would be better though so by pug if your doing it, if you get under the car and have alook at it you can tell weather is gone as it wont be sitting correct and there will be some wear marks on it
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
skard
PostPosted: Tue May 03, 2011 4:59 am Up
had a similar noise recently, mainly on idle.
after replacing the crank pulley, belt and aux tensioner, it turned out to be my alternator pulley or internal bearing on it causing the noise.
i just got a new uprated alternator (with a clutch pulley instead of fixed pulley) and it went away.
eddrj
PostPosted: Tue May 03, 2011 8:56 am Up
ok thanks for repies , i heard they go quickly too ive had mine done twice but do loadsa milliage , it did the trick last time noise went , also what damage can it do ?
il get my mechanic to do it asap for peace of mind .
Its the common fault with the 2.0 Hdi heard it too many times just wasnt sure how long they meana last and
i had the better more expensive newer pulley because there's a few older cheaper one not meant to last for as long.
No havent checked other pulleys yet just thought it probably be bottom pulley .
PostPosted: Tue May 03, 2011 10:35 am Up
Remember:
Buy a NEW GENUINE part from your Peugeot / Citroen main dealer, the pulley has been modified Wink
Fit the modified pulley & it should be fine for the rest of the life of the car.
eddrj
PostPosted: Tue May 03, 2011 12:18 pm Up
ok thought i did that less there's a even newer one ?? this was a year or so ago
PostPosted: Tue May 03, 2011 12:25 pm Up
Eibach pulley ftw Cool
eddrj
PostPosted: Tue May 03, 2011 12:27 pm Up
huh ? isnt genuine peugeot part best ? well i had the newer one and think needs doin again .
Never heard or seen the eibach pulley how much is it ?
how often do you have your bottom pulley done Lee ?
Mabey its just because its a old diesel with very very high milliage ?
PostPosted: Tue May 03, 2011 12:32 pm Up
Bought it thru the local motor factors, paid about £60. Had the original and then the Eibach one. My car is about the same age as yours Wink
eddrj
PostPosted: Tue May 03, 2011 1:02 pm Up
ok thanks
PostPosted: Tue May 03, 2011 1:05 pm Up
if you get the measurment of the pulley you can have even more choices, light weight alloy one do looks good.
eddrj
PostPosted: Tue May 17, 2011 1:46 pm Up
got it all done for bout £130 total ,
tapping noise is still there sometimes il just live with it .
benjy
PostPosted: Thu Nov 24, 2011 5:50 am Up
hi guys i know that this is a page for a 2.0ltr however i have just purchased a 1.4hdi 2005 plate 206 car derived van and there is a loud ticking sound coming form the engine which appears and disappers at regular intervals reading your posts i presume it is the crank shaft pulley and if so is it a difficult job to do and or expensive thanks for your replies
ben
boldham
