Online Now [110]:
Visitors: 109
Today: 43454
Total: 105306768
Forums › The Car › 206 Problems › Driverside ABS Ring
Driverside ABS Ring
Squeaker
PostPosted: Tue May 03, 2011 9:39 am Up
This is the problem Confused
So the ABS ring is cracked and needs replacing, i've seen a 'How to' to change the CV Joint, but there isn't any pictures and before i get the angle grinder to anything, i wanna see what i should be cutting.
Now i've found the CV Joint @ www.jandrcvjoints.co.u...-4501.html think its the right one for the 1.6 Hdi Gti, not too expensive at £17, but they also sell the full driveshaft www.jandrcvjoints.co.u...-4583.html for £50, i imagine, swapping out the full drive shaft and putting the complete new one in, will or should be easier than just fitting the CV Joint, or isn't it too difficult?
So thats my question really, whats the easier way to fix this.
Also which is the side that when you pull the drive shaft out, the gearbox empties itself of oil?
PostPosted: Tue May 03, 2011 9:52 am Up
Drivers driveshaft is a pain to swap, spesh if it gets stuck in the engine mount
But some people take it out to do the CV joint, makes life easier
Can be done on the car, i personally just replace the shaft but that is a lot cheaper
A18NHH
PostPosted: Tue May 03, 2011 10:21 am Up
just replace the ABS ring Very Happy
Wahoo!
Andy180
PostPosted: Tue May 03, 2011 10:31 am Up
as above just replace the abs ring its alot cheaper and a pretty easy job
GTI 180
Squeaker
PostPosted: Tue May 03, 2011 10:48 am Up
How easy is pretty easy? I cant imagine it just slides on and off?
I changed the whole shaft on mine. More new parts = better. Genuine Peugeot to because Euro Car Parts sent a splindly thin aftermarket shaft. Would have fitted but wouldn't be as strong.
Andy180
PostPosted: Tue May 03, 2011 11:11 am Up
Mine just came straight of i would imagine yours would be the same seein as its cracked and to get it on i just stuck the new ring in the oven for 25 minutes to heat it up then tapped it back onto the driveshaft not hard at all.
GTI 180
Squeaker
PostPosted: Tue May 03, 2011 11:48 am Up
If i just change the ring, how do you determine if its 86mm or 90mm?
Andy180
PostPosted: Tue May 03, 2011 12:18 pm Up
its 86mm for the gti and the 180 and 90 for the 2.0 hdi not sure on the 1.6 hdi does it share its drishafts with the gti's or the 2.0 hdi ?
GTI 180
PostPosted: Tue May 03, 2011 12:44 pm Up
What's thee vin number?
Lecktorious
PostPosted: Tue May 03, 2011 12:55 pm Up
Trade Rating: +59
It's 86, I replaced mine not long ago.
'98 Nile Blue 306 GTi 6
PostPosted: Tue May 03, 2011 12:59 pm Up
pretty sure it depends on year as gti, 180gti and 2.0 HDi use the same shaft Laughing
Squeaker
PostPosted: Tue May 03, 2011 1:15 pm Up
I'll PM it you in a second, just to be on safe side. Smile Did i read somewhere you've got the full bagamashings software now? Whats the Yorrkshire/L1 going rate Wink
probably same then, i replied to you on other thread about your fap and what it all meant as i didnt get it.
Squeaker
PostPosted: Tue May 03, 2011 1:37 pm Up
Does the 1.6 diesel share a lot of component parts with the petrol GTi's?
