Posted: Thu Apr 28, 2011 9:12 am |
my central locking is playing up!! sometimes it works when i lock the car & use the dead lock. then when i try & unlock it, it wont unlock! key fob light flashes but no joy! if i open any door manualy the alarm goes off but as soon as i put the key in the ignition & turn it ,alarm goes off & key fob locks/unlocks the car fine untill the next time,SAME PROBLEM..
car is a 99 spec gti two button key fob....its as if the ecu dosnt recognise the key.. anyone know how to fix this probably??
NEW KEY FOB BATTERY FITTED..
Posted: Thu Apr 28, 2011 9:20 am |
Have you resynced the key fob?
I can help with muxed but never done a pre plex.
Posted: Thu Apr 28, 2011 9:21 am |
how could it of gone out of sync?/
Posted: Thu Apr 28, 2011 9:25 am |
Dropping it can do it, Ford used to do it if you left it without power for more than 2 minutes.
www.206info.co.uk/Foru...c+key.html Thers the how to. Try that and see if it works. If not at least it's one thing discounted.
Posted: Thu Apr 28, 2011 9:28 am |
ooo mine started to do that for about a week.. and then the whole car died and now I'm having the whole ECU rebuilt!
Posted: Fri Apr 29, 2011 1:53 am |
so my ecu is on its way out??
Posted: Mon May 02, 2011 9:11 am |
ANYONE??
Posted: Mon May 02, 2011 9:42 am |
| oldbanger2 wrote: |
| so my ecu is on its way out?? |
Wouldn't think so. Could be other things causing the problem.
Have you tried re-syncing?
Is the battery definately good (even if new, measure it.)?
Posted: Tue May 03, 2011 4:28 am |
tried re-syncing that works, but then after its locked for a few min and i try to unlock with button keyfob it wont unlock. i have to do it manually! i open the door & alarm starts going.. i put key in ignition & turn it ,alarm turns off.. key then locks/deadlocks/ opens the car..leave it 20 min.. keyfob buttons wont unlock car...battery is new....
Posted: Tue May 03, 2011 5:40 am |
| oldbanger2 wrote: |
| battery is new.... |
Might be a dud.
Was it doing it before change of battery? If so its not that.
Clutching at straws but is your keyfob OK? Try with a mate's keyfob if available (sync it).
Posted: Tue May 03, 2011 10:32 am |
| V9977 wrote: |
Clutching at straws but is your keyfob OK? Try with a mate's keyfob if available (sync it). |
Need Peugeot Planet to code a keyfob to a different car
You cant sync a keyfob unless it has already been coded to the car in question BSI unit.
Posted: Tue May 03, 2011 11:49 am |
it has been working fine ,just started playing up 2month ago, thought it was battery , new one fitted still playing up..
& yes it just started doing it before i got new battery..
Posted: Tue May 03, 2011 12:17 pm |
| MrBSI wrote: |
| V9977 wrote: |
You cant sync a keyfob unless it has already been coded to the car in question BSI unit. |
Ah yes. That would make sense otherwise zero security.
Scratch that.
Posted: Tue May 03, 2011 12:19 pm |
You also need the 4 digit alphanumeric security code before the BSI will even allow any keys / remotes to be coded.
Posted: Tue May 03, 2011 12:24 pm |
Lee knows it.
