Online Now [401]:
Visitors: 400
Today: 30114
Total: 105293534
Forums › The Car › 206 Talk › Servicing cost
Servicing cost
acotton21
PostPosted: Tue May 03, 2011 2:52 pm Up
Car not had it done in a while and thinking of full service?
Does anyone know how much its likely to cost?
PostPosted: Tue May 03, 2011 2:53 pm Up
what car?
acotton21
PostPosted: Tue May 03, 2011 2:54 pm Up
Seabook wrote:
what car?
Embarassed sorry 206 1.4lx
Squeaker
Depends if you're doing it yourself?
Did mine today:
Oil Total Quartz 7000 £28
Oil Filter
Air Filter
Sump Plug Washer £20 ( should of been more, dealer had no change Smile )
An hour in time.
Maybe throw in a fuel filter on top, don't know how much they are for yours mind.
acotton21
PostPosted: Tue May 03, 2011 2:56 pm Up
how much from a garage?
PostPosted: Tue May 03, 2011 2:57 pm Up
between 50 to 200.
anton7350
PostPosted: Tue May 03, 2011 3:13 pm Up
i got quotes from 140 to 180 for my wee 1.1, ended up doing it my self after i had to change my oil sump my self, really is quite easy and your saving a good load too mate Wink
206 1.1 style in blue Cool
PostPosted: Tue May 03, 2011 3:21 pm Up
Don't forget the pollen filter.
Bigbenj_08
PostPosted: Tue May 03, 2011 3:26 pm Up
£180 from pug for a 40k service... only really covers the basics though.
I've spent around £100 doing my car myself, but have upgraded a few bits from standard ie air filter, oil, spark plugs.
Aegean Blue 1.6 16v Sport
abs06
PostPosted: Tue May 03, 2011 5:28 pm Up
I did mine myself
But might be an idea to ask the garage/dealer u got urs from. If u didnt buy private. I called the garagae i got mine from. And they offered 145 for full service. With courtesy car. Only reason i didnt was because it was 10 miles from my work and my work is 23 miles from home. And i do 12 hour shifts
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
ExoVyper
PostPosted: Tue May 03, 2011 5:40 pm Up
Did mine today:
Oil Filter
Air Filter
An hour in time.
Surprised !
for a copper washer?
dear god!
Squeaker
PostPosted: Wed May 04, 2011 3:08 am Up
ExoVyper wrote:
Did mine today:
Oil Filter
Air Filter
An hour in time.
Surprised !
dear god!
And its not even copper now..........
Kersh
PostPosted: Wed May 04, 2011 3:16 am Up
people forget that when your car is serviced a lot of other stuff is checked over too.
its all very well doing it yourself ( ive done my own services for years) but you still need to get it checked over every now and then by someone that knows what they are doing unless you know a lot about telltale signs of wear in components etc.
Member number: 36
Bigbenj_08
PostPosted: Wed May 04, 2011 5:36 am Up
Isn't that what an MOT is for though?
Lewis1592
PostPosted: Wed May 04, 2011 3:34 pm Up
just be wary if you have breakdown cover. ive got AA and they have in there small print that my car has to be serviced by a garage, pain in the a**e. but knowing my luck ill cancel it and then break down.
2001, 206 1.4 lx first car Very Happy
