Latest: Beduff1977
Overall: 17134
Online Now [1986]:
Visitors: 1985
Today: 132166
Total: 109986685
Forums › The Car › 206 Talk › Anti Pollution Fault/ Unblock Diesel Filter Queries
Go to page Previous  1, 2
Squeaker
PostPosted: Tue May 03, 2011 2:58 pm Up
Gonna get Lee to do mine, Lee will you be able to tell me that too?
Lecktorious
PostPosted: Tue May 03, 2011 3:01 pm Up
Trade Rating: +59
I think he should be able to if he's using PPS - there is a very recent, new release of dealer diag software but my car was read using PPS.
'98 Nile Blue 306 GTi 6
PostPosted: Tue May 03, 2011 3:56 pm Up
I'm running software newer than some dealers Wink
Squeaker
PostPosted: Wed May 04, 2011 12:06 pm Up
G. wrote:
Fast idle MB reading for a clear FAP should be approx 30MB - mine was not a kick in the a**e off 300MB! Shocked
I see your 300 and raise ya 348mb Shocked
Codes that came up on mine were:
P1351
P0420.
What were the ones on yours G? Also do you or your mate now how to force a regen with the software?
I'm thinking the glow plug failure has stopped it regenerating for however how long, does that sound feasible?
Oh and cheers for the scan Lee Smile Got the message back before i even got off Lidget Lane Laughing
Lecktorious
PostPosted: Wed May 04, 2011 5:17 pm Up
Trade Rating: +59
Bloody hell Shocked Laughing
What do the codes actually read as?
I had 'open fuel cap circuit' - this meaning the sensor that injects the cerine fluid into the fuel tank is knackered. No cerine = no regeneration!
Cannae mind what the other was but I was told not to worry about it.
Nah regeneration on mine was impossible. As there's no cerine mixing with the diesel the soot in the DPF isn't getting burned off. That and my DPF is too far gone now to allow regeneration.
Tis getting steam cleaned out on Friday, will need to get a new fuel cap sensor ordered up too.
Squeaker
PostPosted: Wed May 04, 2011 6:23 pm Up
P1351 Is Post/Pre heating relay circuit, or failed glow plugs/relay. Hope its the plugs and not the relay, just ordered a set of 4 new NGK glow plugs.
P0420 Is that the FAP is overloaded.
But in the regen process, the glow plugs are turned on and extra fuel is thrown into the engine, to get it hot enough to burn the soot off.
I'm hoping when i put the new glow plugs in, it does a proper regen.
They are the same in the 1.4 so again i hope i can use Haynes on the 1.4 as a guide. because the 1.6 isnt in the Haynes.......
Lecktorious
PostPosted: Thu May 05, 2011 6:16 am Up
Trade Rating: +59
You can fit new glow plugs, but with those MB readings I doubt the DPF will regenerate as it's too blocked. Mine wasn't for happening and it was less blocked than yours!
MrrNoName
PostPosted: Thu May 05, 2011 7:47 am Up
lol that made me laugh
PostPosted: Thu May 05, 2011 1:59 pm Up
Send me your email address and I'll send you a guide on how to strip that engine.
Lecktorious
PostPosted: Thu May 05, 2011 2:09 pm Up
Trade Rating: +59
Is that including removing the DPF filter Lee, aye?
PostPosted: Thu May 05, 2011 2:48 pm Up
www.ld-automotive.co.u...ne_dv6.pdf
Page 2 of 2
