Online Now [121]:
Visitors: 121
Today: 31884
Total: 116574268
Forums › The Car › 206 Problems › How do I bleed this - radiator
Go to page Previous  1, 2
PostPosted: Mon May 02, 2011 9:00 am Up
Lee wrote:
What? save peugeot 20p? Laughing
It is peugeot remember Laughing
Have fun though, and dont forget you porbs need to drain brake fluid soon Wink
PostPosted: Mon May 02, 2011 9:04 am Up
Done it Smile
The drivers bleed screw was a b***h tho
dumdum0910
PostPosted: Mon May 02, 2011 3:13 pm Up
same rad as mine... you dont even need to undo the bleed screw. just fill up the coolant bottle and let it warm up with the cap off the bottle and top up as needed.
PostPosted: Mon May 02, 2011 4:51 pm Up
If you're changing the coolant, course you need to open the bleed screws to let the air out of it.
Think of you radiators at home, you bleed them...dont you
dumdum0910
PostPosted: Mon May 02, 2011 4:58 pm Up
i did change the coolant . the system bleed its self . once the thermostate had opened. and with the cap off the coolant bottle air is able to escape. havent had any problems yet
PostPosted: Mon May 02, 2011 5:01 pm Up
What He Said
it might takes a while but it do work
qwert
PostPosted: Wed May 04, 2011 5:38 am Up
hi. I am hoping to do this on my 206 SW 2 litre TD this weekend. So would i just remove the bottom pipe, let all the water run out. Then fill it back up, leave the cap off the water tank, then start the car and let it get hot and it would bleed itself?
Thank you
brum brum
PostPosted: Wed May 04, 2011 11:05 am Up
If you could rely on the system self bleeding do you think they would have still fitted bleed screws?
You can bleed most of the system without even switching the engine on.
gixxerkev
PostPosted: Wed May 04, 2011 12:09 pm Up
The system has to be bled as the heater pipes and matrix are a bit higher or the same level than the resevoir, bubbles dont go downhill !!! basic physics.
An Ex '03 1.4 GLX driver, German technology all the way now.
Page 2 of 2
