Latest: Beduff1977
Overall: 17134
Online Now [633]:
Visitors: 632
Today: 124928
Total: 108940733
Forums › The Car › 206 Talk › NGK Plugs- Whats the issue?
PostPosted: Thu May 05, 2011 8:49 am Up
Use the SEARCH Rolling Eyes
NGK plug issues have been covered many times on here Wink
PostPosted: Thu May 05, 2011 9:53 am Up
Timon2210 wrote:
206 hates them because they are called "NGK"...lol Very Happy
I Dont get it... Is there some pun for NGK I dont know about?
I'm just kidding mate,but NGK plugs are trash when used with Pug 206 and maybe some other models too.
MrrNoName
PostPosted: Thu May 05, 2011 9:56 am Up
the OPs question was to why exactly are they incompatible (for what reason do they not function properly) when they are sold as being suitable, something that no-ones answered Razz lol
PostPosted: Thu May 05, 2011 10:01 am Up
MrrNoName wrote:
the OPs question was to why exactly are they incompatible when they are sold as being suitable, something that no-ones answered Razz
Ive answered this question before on the forum:
The phase detection system built in to the coil pack that detects misfires is incompatible with NGK spark plugs.
With NGK plugs fitted you can end up with the HT ignition voltage instead of firing the spark plug it ends up being sent back down the wiring loom which can fry the engine ecu.
It was such a problem that PSA Peugeot / Citroen sent out a technical service bulletin to there dealer networks warning of the issue!
PostPosted: Thu May 05, 2011 10:13 am Up
Thanks you Smile
Could they damage the coil pack at all?
PostPosted: Thu May 05, 2011 10:16 am Up
Thanks you Smile
Possibly.
Bouricord or Electrofil for the coil pack.
Hope you aint got the original Sagem piece of s**te on there Laughing
Any idea if your car has had the earth wire mod fitted to the coil pack connector plug?
PostPosted: Thu May 05, 2011 10:18 am Up
Thanks you Smile
Possibly.
Somethings tell me I think ive got the Sagem pack. No idea on the mod either.
Im just trying to think of what could be causing mine to intermintently (sp?) cut out when I put the clutch in.
PostPosted: Thu May 05, 2011 10:24 am Up
It will have the nasty word SAGEM on it somewhere if it one Wink
For the mod:
Peugeot / Citroen part number 6555 K9 Suppressor
Splice one end in to pin 4 on the connector plug, the other end needs to be earthed to the engine block.
Have a look, it might already be fitted.
PostPosted: Thu May 05, 2011 10:31 am Up
For the mod:
I think ive seen that word on it before, either that or im thinking of one of the 50 millions peugeot coil packs ive seen over the years.
Dont think it has the mod, litterally had the plug going into the pack with 4 wires, nothing else going anywhere. What does it do?
I would go check , but the weather says otherwise....
PostPosted: Thu May 05, 2011 10:34 am Up
Smooths out any electrical spikes on the coil pack wiring.
PostPosted: Thu May 05, 2011 10:37 am Up
i believe my car has one fitted?? (well did as there is no engine in car now Laughing )
i225.photobucket.com/a...e35cb0.jpg
Ah right. Ill look into it. Just wanna work out, why it's so hessitent to come off idle and rev up to about 2,000 rpm. It seems to take forever to get to there but once you get there it just takes off. (Not litterally but it does rev up quicker than it did pre 2k rpm.)
sahdra
PostPosted: Fri Jul 22, 2011 1:00 am Up
Don't ngk's come as standard in the 180?
Black GTi 180/SP pack
PostPosted: Fri Jul 22, 2011 2:35 am Up
no
JE_180
PostPosted: Fri Jul 22, 2011 2:37 am Up
No Bosch spark plugs are standard on the 180's, get Bosch Super 4's !
Page 2 of 3
