Posted: Thu May 05, 2011 8:49 am |
Use the SEARCH
NGK plug issues have been covered many times on here
Posted: Thu May 05, 2011 9:53 am |
LeeThr wrote: |
Timon2210 wrote: |
206 hates them because they are called "NGK"...lol  |
I Dont get it... Is there some pun for NGK I dont know about? |
I'm just kidding mate,but NGK plugs are trash when used with Pug 206 and maybe some other models too.
Posted: Thu May 05, 2011 9:56 am |
the OPs question was to why exactly are they incompatible (for what reason do they not function properly) when they are sold as being suitable, something that no-ones answered lol
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Thu May 05, 2011 10:01 am |
MrrNoName wrote: |
the OPs question was to why exactly are they incompatible when they are sold as being suitable, something that no-ones answered  |
Ive answered this question before on the forum:
The phase detection system built in to the coil pack that detects misfires is incompatible with NGK spark plugs.
With NGK plugs fitted you can end up with the HT ignition voltage instead of firing the spark plug it ends up being sent back down the wiring loom which can fry the engine ecu.
It was such a problem that PSA Peugeot / Citroen sent out a technical service bulletin to there dealer networks warning of the issue!
Posted: Thu May 05, 2011 10:13 am |
MrBSI wrote: |
MrrNoName wrote: |
It was such a problem that PSA Peugeot / Citroen sent out a technical service bulletin to there dealer networks warning of the issue! |
Thanks you
Could they damage the coil pack at all?
Posted: Thu May 05, 2011 10:16 am |
LeeThr wrote: |
MrBSI wrote: |
MrrNoName wrote: |
Thanks you
Could they damage the coil pack at all? |
Possibly.
Bouricord or Electrofil for the coil pack.
Hope you aint got the original Sagem piece of s**te on there
Any idea if your car has had the earth wire mod fitted to the coil pack connector plug?
Posted: Thu May 05, 2011 10:18 am |
MrBSI wrote: |
LeeThr wrote: |
MrBSI wrote: |
MrrNoName wrote: |
Thanks you
Possibly.
Any idea if your car has had the earth wire mod fitted to the coil pack connector plug? |
Somethings tell me I think ive got the Sagem pack. No idea on the mod either.
Im just trying to think of what could be causing mine to intermintently (sp?) cut out when I put the clutch in.
Posted: Thu May 05, 2011 10:24 am |
LeeThr wrote: |
It will have the nasty word SAGEM on it somewhere if it one
For the mod:
Peugeot / Citroen part number 6555 K9 Suppressor
Splice one end in to pin 4 on the connector plug, the other end needs to be earthed to the engine block.
Have a look, it might already be fitted.
Posted: Thu May 05, 2011 10:31 am |
MrBSI wrote: |
LeeThr wrote: |
For the mod:
Have a look, it might already be fitted. |
I think ive seen that word on it before, either that or im thinking of one of the 50 millions peugeot coil packs ive seen over the years.
Dont think it has the mod, litterally had the plug going into the pack with 4 wires, nothing else going anywhere. What does it do?
I would go check , but the weather says otherwise....
Posted: Thu May 05, 2011 10:34 am |
LeeThr wrote: |
Smooths out any electrical spikes on the coil pack wiring.
Posted: Thu May 05, 2011 10:37 am |
MrBSI wrote: |
LeeThr wrote: |
Smooths out any electrical spikes on the coil pack wiring. |
Ah right. Ill look into it. Just wanna work out, why it's so hessitent to come off idle and rev up to about 2,000 rpm. It seems to take forever to get to there but once you get there it just takes off. (Not litterally but it does rev up quicker than it did pre 2k rpm.)
Posted: Fri Jul 22, 2011 1:00 am |
Don't ngk's come as standard in the 180?
Posted: Fri Jul 22, 2011 2:35 am |
sahdra wrote: |
Don't ngk's come as standard in the 180? |
no
Posted: Fri Jul 22, 2011 2:37 am |
No Bosch spark plugs are standard on the 180's, get Bosch Super 4's !
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
