Online Now [256]:
Visitors: 255
Today: 51002
Total: 143119449
Forums › The Car › 206 Talk › Would this induction kit fit my car?
acotton21
PostPosted: Fri May 06, 2011 12:26 am Up
Click
I have a 2001 (51) 1.4LX 206?
bashyy1
PostPosted: Fri May 06, 2011 12:33 am Up
Link doesn't work
Aegean Blue Gti 180.
Project Thread
acotton21
PostPosted: Fri May 06, 2011 12:37 am Up
Try again?
bashyy1
PostPosted: Fri May 06, 2011 12:40 am Up
I'd say it will fit...
Fits
Peugeot 206 1.4 1.6 16v 1999-2004.
Project Thread
acotton21
PostPosted: Fri May 06, 2011 12:43 am Up
cheers Smile just never know with ebay so thought id just check with people that have 206's Smile
Bigbenj_08
PostPosted: Fri May 06, 2011 12:48 am Up
depends.... I had one simiar and the fitment was s**te.
The scoop thing sits flush against the bonnet and the gap was right over the radiator so would be sucking in hot air.
I couldn't figure out how to get it to fit properly!
Aegean Blue 1.6 16v Sport
bashyy1
PostPosted: Fri May 06, 2011 12:54 am Up
Its supposed to be fit behind the grill i think.
Project Thread
bashyy1
PostPosted: Fri May 06, 2011 12:55 am Up
I'd recommend K&N though.
Project Thread
acotton21
PostPosted: Fri May 06, 2011 12:58 am Up
what one?
Lewis
PostPosted: Fri May 06, 2011 3:53 am Up
You probably have an 8v engine and the air intake is in a different place than the 16v engine so this will probably not fit! it will be the wrong shape...
Tivoli LX 1.1
Black GTI 180
White VXR Burg
acotton21
PostPosted: Fri May 06, 2011 3:54 am Up
Would would you recomend i get?
Andrew
PostPosted: Fri May 06, 2011 5:40 am Up
A green cotton panel filter in your standard box, avoid that one as it appears to be shorter so it would be drawing in hot air from the rocker as well as the radiator
Peugeot did a good job on the standard box, thats why they mass produced it Wink
My 206 thread
www.detailedbyandrew.com
acotton21
PostPosted: Fri May 06, 2011 5:45 am Up
were from?
luwegi
PostPosted: Fri May 06, 2011 7:00 am Up
K and N website Smile
206 GTi 138, 156bhp for now...
Davels
PostPosted: Fri May 06, 2011 7:13 am Up
The K&N website will have the K&N panel filter.
Green cotton panel filters although green in colour, they are also made by the company "Green" and are available online. Razz Quick google search should return a list of UK stockist where you can select your model and engine.
K&N are cheaper and good quality with lifetime warrenty. Green are more expensive and are generally used in turbo cars with sensitve MAF sensors, particularly SEATS. The reason being K&N's cotton is oiled more and this can foul the sensor. No such problem on pugs or not that I have heard anyway.
K&N will be fine for your car. You won't have any real change in induction noise from the engine but you may see as much 2-3bhp increase on a good day rather than loose power like most induction kits due to hot air being drawn in from the engine bay.
If you want the noise go for the full induction kit and cone, but you may a bit of oomp during the summer months.
And of course declare everything Cool
