Posted: Sun May 08, 2011 6:02 am |
bigtony85 wrote: |
mine is very slow to accelerate when i first get in it in the mornings. then all of a sudden it will accelerate like hell. and yeh its got ngk plugs in it but its had them in since ive had it (2 n half years) and this probably has only just started bout 3 months ago |
Change the ngk plugs for bosh super 4s I used NGks once nod it ran cr*p with no power they mess with the coil pack. Once its warm does Is accelerate hard low down then a little harder over about 3500-4000 rpm?
| | ![](images/spacer.gif) |
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Sun May 08, 2011 6:04 am |
bigtony85 wrote: |
has one every year cause i only do bout 6000 a year. and ive just done it bout 3 weeks ago |
Clearly not a proper service if the plugs are 2 and a half years old
Posted: Sun May 08, 2011 6:08 am |
LEE it had a new set 3 weeks ago. i was sayin even tho ive changed them 3 times ive always changed them 4 NGKs and NICK ive never had problems with NGKs tbh. and nick yeh it does do that.
| drive fast !!! live life faster !!! | |
Posted: Sun May 08, 2011 6:11 am |
Ye think you have never had a problem with the NGks but have you driven it with bosh super 4s in? You WILL notice a throttle and power difference I was noticeable on mine.
As for the acceleration if it's doing that your vvt sensor is fine then.
Posted: Sun May 08, 2011 6:13 am |
coolio might try n change them nick. cheers dude
Posted: Sun May 08, 2011 6:15 am |
Super Plus are the newer ones
Posted: Sun May 08, 2011 6:16 am |
Alot of people on here will advice you to use bosh super 4s. And I'm speaking from experience. No probably hope you get it sorted.
Posted: Sun May 08, 2011 6:43 am |
so whats better super plus or super 4???
Posted: Sun May 08, 2011 6:49 am |
nick180 wrote: |
Ye think you have never had a problem with the NGks but have you driven it with bosh super 4s in? You WILL notice a throttle and power difference I was noticeable on mine. |
Your original plugs must have been knackered then. All a spark plug can ever do is create a strong spark. Super 4's will create the same single spark that any other plugs will do.
Posted: Sun May 08, 2011 7:40 am |
It had super 4s in it I did a full service on it using ngk plugs went for a drive noticed it was down on power next day changed back to super 4s and it was back to narmal.
Posted: Sun May 08, 2011 8:32 am |
I always use the NGK in my 180 rally car. I have always been told the standard bosch plugs are very poor. But Edward is correct all a plug does is spark nothing more so what quality you buy will really just depend on how long they will last against the cost of them
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Sun May 08, 2011 9:03 am |
NGK can cause problems with your coilpack and potentially ECU. That's why Peugeot issued a service bulletin about not fitting them
Posted: Sun May 08, 2011 9:17 am |
Lee wrote: |
NGK can cause problems with your coilpack and potentially ECU. That's why Peugeot issued a service bulletin about not fitting them |
I was also told about the this when I worked for Peugeot.
Posted: Sun May 08, 2011 9:35 am |
nick180 wrote: |
Lee wrote: |
I was also told about the this when I worked for Peugeot. |
Only dickheads fit NGK's to a PSA engine
Fingers crossed it blows his ecu ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Sun May 08, 2011 9:38 am |
MrBSI wrote: |
nick180 wrote: |
Lee wrote: |
Fingers crossed it blows his ecu ![Laughing Laughing](images/smiles/icon_lol.gif) |
easy mate !!!!!!! ive never hurd this b4 or been told any of this thats y ive got NGKs fitted
