Online Now [234]:
Visitors: 233
Today: 76873
Total: 143066932
Forums › The Car › 206 Talk › Gti 180 Fuel Filter
Gti 180 Fuel Filter
NICKST
PostPosted: Sun May 08, 2011 6:02 am Up
bigtony85 wrote:
mine is very slow to accelerate when i first get in it in the mornings. then all of a sudden it will accelerate like hell. and yeh its got ngk plugs in it but its had them in since ive had it (2 n half years) and this probably has only just started bout 3 months ago
Change the ngk plugs for bosh super 4s I used NGks once nod it ran cr*p with no power they mess with the coil pack. Once its warm does Is accelerate hard low down then a little harder over about 3500-4000 rpm?
PostPosted: Sun May 08, 2011 6:04 am Up
bigtony85 wrote:
has one every year cause i only do bout 6000 a year. and ive just done it bout 3 weeks ago
Clearly not a proper service if the plugs are 2 and a half years old
bigtony85
PostPosted: Sun May 08, 2011 6:08 am Up
LEE it had a new set 3 weeks ago. i was sayin even tho ive changed them 3 times ive always changed them 4 NGKs and NICK ive never had problems with NGKs tbh. and nick yeh it does do that.
drive fast !!! live life faster !!!
NICKST
PostPosted: Sun May 08, 2011 6:11 am Up
Ye think you have never had a problem with the NGks but have you driven it with bosh super 4s in? You WILL notice a throttle and power difference I was noticeable on mine.
As for the acceleration if it's doing that your vvt sensor is fine then.
bigtony85
PostPosted: Sun May 08, 2011 6:13 am Up
coolio might try n change them nick. cheers dude
PostPosted: Sun May 08, 2011 6:15 am Up
Super Plus are the newer ones
NICKST
PostPosted: Sun May 08, 2011 6:16 am Up
Alot of people on here will advice you to use bosh super 4s. And I'm speaking from experience. No probably hope you get it sorted.
bigtony85
PostPosted: Sun May 08, 2011 6:43 am Up
so whats better super plus or super 4???
PostPosted: Sun May 08, 2011 6:49 am Up
Your original plugs must have been knackered then. All a spark plug can ever do is create a strong spark. Super 4's will create the same single spark that any other plugs will do.
NICKST
PostPosted: Sun May 08, 2011 7:40 am Up
It had super 4s in it I did a full service on it using ngk plugs went for a drive noticed it was down on power next day changed back to super 4s and it was back to narmal.
imjeeves
PostPosted: Sun May 08, 2011 8:32 am Up
I always use the NGK in my 180 rally car. I have always been told the standard bosch plugs are very poor. But Edward is correct all a plug does is spark nothing more so what quality you buy will really just depend on how long they will last against the cost of them
PostPosted: Sun May 08, 2011 9:03 am Up
NGK can cause problems with your coilpack and potentially ECU. That's why Peugeot issued a service bulletin about not fitting them
NICKST
PostPosted: Sun May 08, 2011 9:17 am Up
I was also told about the this when I worked for Peugeot.
PostPosted: Sun May 08, 2011 9:35 am Up
Only dickheads fit NGK's to a PSA engine Wink Laughing
Fingers crossed it blows his ecu Laughing
bigtony85
PostPosted: Sun May 08, 2011 9:38 am Up
easy mate !!!!!!! ive never hurd this b4 or been told any of this thats y ive got NGKs fitted
Page 2 of 3
