Latest: Beduff1977
Overall: 17134
Online Now [674]:
Visitors: 673
Today: 134140
Total: 108276781
Forums › The Car › 206 Problems › long drive ahead.
long drive ahead.
jedwards
PostPosted: Sun May 08, 2011 6:20 am Up
alright guys! im back again with more cooling questions! i have a 800 mile drive to do in a few weeks time and im really worrying about the car!
i cannot get it to stay at 90 degrees when going 70 and thats only with me in the car, when i do the drive its going to have 3 people in their!
i've had a new rad, a new thermostat (when the headgasket got done 6 months ago and its overheated a few times since then) flushed the cooling, fresh coolant and ive even taken the air con condenser out to improve air flow!
I really need this sorted as i cannot afford for the head gasket to go again especially when im at the wrong end of the country!
the fan kicks in at 103 degrees but i've seen a few posts on here with people saying their fans kick in at 93?
I really dont know what else i can really do so any help would be smashing Very Happy
just in case anyone hasnt seen my other rants the cars a 1.4lx 8v 1999
dsdasdsad
PostPosted: Sun May 08, 2011 6:21 am Up
Is it overheating then?
jedwards
PostPosted: Sun May 08, 2011 6:24 am Up
yeah as soon as im going 70 for over a mile its goes up to 103 fan kicks in but wont go back down unless i slow down or put it in neutral, was overheating in traffic until i got my new rad..
although i dunno what its gonna be like when the weather gets hot!
dsdasdsad
PostPosted: Sun May 08, 2011 6:37 am Up
Fan running at high or low speed?
If you are driving 70, it shouldn't overheat tbh because the cool air hitting the front of the car should cool the engine down.
The needle on the cluster is accurate isn't it? and the temp sensor?
No air in the cooling system?
jedwards
PostPosted: Sun May 08, 2011 6:41 am Up
there's no air in the coolant system, when i've tested the fan when its at a standstill it seems to run fast but i didnt know there was two speeds?
it mainly goes up on inclines obvs doesnt when im going downhill
as for the needle i have no idea how id know if it was accurate? and is the temp sensor built into the thermostat or not?
do you know of any good degreasers as it could still have quite a lot of oil in the system maybe?
dsdasdsad
Seb
PostPosted: Sun May 08, 2011 6:48 am Up
Staff - Seb
Water pump buggered?
jedwards
PostPosted: Sun May 08, 2011 6:50 am Up
i did think that, any signs if it has gone? and its quite a job to do is it not?
dsdasdsad
PostPosted: Sun May 08, 2011 7:04 am Up
You had the timing belt done?
jedwards
PostPosted: Sun May 08, 2011 8:43 am Up
yeah the cambelt was done when the headgasket was replaced, it hadnt been done since leaving the factory, headgasket was done 6000 miles ago at 90000
dsdasdsad
PostPosted: Sun May 08, 2011 9:05 am Up
Water pump normally gets changed when the cambelt does. Did they do it?
jedwards
PostPosted: Sun May 08, 2011 9:26 am Up
not sure actually, gonna check the invoice now, if you change the water pump does the cambelt need doing at the same time?
dsdasdsad
PostPosted: Sun May 08, 2011 10:01 am Up
NON bio washing up liquid / powder or dishwashing tablets.
MUST be NON bio Wink
Couple of tablets added to the expansion bottle when cold & take the car for a drive to get it nice & hot, smells lovely & also cleans all the crap out the cooling system at them same time better then stuff you can buy on the shelf.
jedwards
PostPosted: Sun May 08, 2011 10:16 am Up
awesome! will it need flushing afterwards?
dsdasdsad
jedwards
PostPosted: Sun May 08, 2011 10:18 am Up
also am going to replace the system coolant temperature sensor & the coolant temperature gauge sensor, where would be the best place to find them?
dsdasdsad
PostPosted: Sun May 08, 2011 11:41 am Up
Peugeot main dealer Wink
